Polacca-Sciabecco franceze Mistique [COMPLETED BUILD]
Hi guys.Well I drilled a bunch of holes for dowel.Also drilled holes in the sides of the clews.Tried saith a few nails into the deck.Something like that would be.
IMG_20191128_123444.jpgIMG_20191128_162304.jpgIMG_20191128_162316.jpgIMG_20191128_123435.jpg
Hi everyone. I’ll continue building the model. I choked the nagel on the deck. I drilled holes in the sides. I started to hammer the nagh in the sides. I sanded the underwater part of the hull and covered it with an oak stain.IMG_20191209_155822.jpgIMG_20191209_155835.jpgIMG_20191209_155933.jpgIMG_20191209_155947.jpgIMG_20191209_160000.jpgIMG_20191209_160004.jpgIMG_20191209_160020.jpg
hi guys.I will continue the story of the construction of the Misticque.Changes little,because of illness,hernia of the spine in the neck.My hand is numb.So far, this is what the model looks like.I'm being treated.Painted the bulwark and bulkhead inside.Set the hatch and bollards.I started making carriages.I'm waiting for a package from Amati with all the little things.
I continue construction.The hand moved a little after the illness.Now I'm working on the guns that are under the deck of the quarterdeck.You must first install them, tie them with tails.Then I'll cover the quarterdeck.IMG_20200220_114212.jpgIMG_20200220_114225.jpgIMG_20200220_114234.jpgIMG_20200220_114247.jpgIMG_20200220_114257.jpgIMG_20200220_114329.jpgIMG_20200222_123830.jpgIMG_20200222_123820.jpg
Hi, everybody.That's what I get.I tied the blocks with tails, put buckets in imitation of water.IMG_20200228_133403.jpgIMG_20200228_133411.jpgIMG_20200228_133454.jpgIMG_20200228_133850.jpgIMG_20200228_133907.jpgIMG_20200228_133931.jpgWe'll have to hide all this beauty under the deck of the quarterdeck.Tell me. can the framework with cannonballs still be installed?
I have a question.Is the rooster grating on the stern too small?Made a 1x1 mm cell..Is it normal for a 1:50 scale?
