G'day Hvjork
Hi, Joe! I have not a printer. I use the service Shapeways and I paid to have my model printed.I used fusion 360 for a bit was to much for me to learn in the time I needed to learn CAD so I ended up using Sketchup and TinkerCad. I still have Fusion so hopefully one day soon I can mess with it again. Nice Print there.What Printer you Running? I'm using the First Gen XYZ that I hacked to run better software on. I have done a lot to the Printer replacing the crap bearings for Boca's, Heated Bed upgrade, extruder upgrade the whole nine yards. I run it on Repetier and Slic3r I have complete control of it with that and no more filament cartridges and I can print any filament I want.
What I have r been reading, they are the best for price ratio. What's your thoughts Joe?Ahh they do great work and they have fantastic Printers
Absolutely are the best price ratio. unless you know someone with a printer as that's always the cheapest way. I vapor bath my printed parts to smooth them out and give the surface a nice gloss finish. I believe Shapeways does the same thing because I have seen some nice work from them. unfortunately it doesn't matter what printer you use $200 or $2000 machine they all have print lines from layers to build the part. I take my parts and suspend them over acetone that I put into a glass container. I put that container in a pot of hot water, this causes the acetone to vaporize. those vapors rise to the part hanging about the container and then smooth everything out, once its as smooth as I like I remove it and rinse it under cold water to hault the process. I believe shapeways does the same but on a larger scale. its the only way to smooth a part other then sanding it which rarely ever looks good when done.What I have r been reading, they are the best for price ratio. What's your thoughts Joe?
Greg
Thank you, Uwek! Now I have more years than I need.
your looking at the future of the hobby when you have a 3D model showing you how everything will look and how it all goes together
