SZKUTNIK can you do Brooklyn class hull? And how much would it cost?
I am in Grenada now, but will get you pics when I get back. BGP plans for a lot of nattlrships are available free from Model Monkey. You’ll have to figure out how to print a great get to 1/350 scale. I originally bought plans from The Floating Drydock site.can you post a picture(s) of what you have done to the banner model before you get another 1 to see what you have done so far? what did you do to build up the bow from the Arizona to the New Mexico? i presume you redid all the hull casements from the Arizona to the New Mexico? where did you get the New Mexico BOGP from & is it in digital format or paper format? i did a kitbash of Revell's 1/429 scale Arizona into the Mississippi back in the late 70's which i still have till i build new corrected versions(ww2 & post war missile gunnery training ship AG-128) then use the old hull for another OBB.
I did the same for New Amex. Details are not as crisp as Ihsd hipe. I will use as a guide for scratch built superstructureDavidp - I made copies both 8.5x11 and to 1/350 scale and placed them in a binder
Trbingham - I found a guy at Shapeways and asked him to 3D print the bow, 01 deck and superstructures for my Idaho and he did. Also, checkout ModelFunShipyard at Shapeways for New Mexico parts as well as Model Monkey
View attachment 353578View attachment 353579
Any idea of price for New New class hull? All 3 ships had same hull configAhoy!
We can design and 3D print the full hull for New Mexico (BB 40) and other models also. Maximum width of hull 26 cm.
combine the 2 linked BOGP drawings together will give you a complete set
BB-42 USS Idaho Booklet of General Plans (1945) (version 1) https://archive.org/details/bb42bogp1945
BB-42 USS Idaho Booklet of General Plans (1945) (version 2) https://archive.org/details/bb42bogp1945v2
what is the diameter of your #2 14" barbette?
what type of 3d resin was used to print that?
figure on replacing the 3d printed yard arm with another material like brass or
I had so barley butchered the Banner hull and had to re-build from waterline up. Only the back fifth stern section is original. All decks and side casemates are from BGP plans. It took a long time to learn how to get every thing to line up in all 3 dimensions.
When I got my latest Banner hull I found it is up to .080” wider than either BGP or Profil Morskie plan show it to be.
can you post a picture(s) of what you have done to the banner model before you get another 1 to see what you have done so far? what did you do to build up the bow from the Arizona to the New Mexico? i presume you redid all the hull casements from the Arizona to the New Mexico? where did you get the New Mexico BOGP from & is it in digital format or paper format? i did a kitbash of Revell's 1/429 scale Arizona into the Mississippi back in the late 70's which i still have till i build new corrected versions(ww2 & post war missile gunnery toraining ship AG-128) then use the old hull for another y
I also got Model Fun Shipyard at Shapeways to do an 01 deck for my New Mexico. I had him print it without wood deck so zi could add my own.Davidp - I made copies both 8.5x11 and to 1/350 scale and placed them in a binder
Cool, I'm glad I could help. Now I just need to find some free time to work on model
If you order, note that there are 3 or 4 types of filaments and finishes. the cheapest one produces a rough grainy finish. Other choices are more expensive, but offer a smoother finishI'll have to check with ModelFunShipyard about the resin, but it looks like a filament style, if that helps. I haven't decided if I will use these pieces for reference and scratch build or paint and call it good.
Thanks, David:your 1st picture of Feb 20 shows the lower part of the bow different to what you just posted which is why i asked the question. watch it with the Profile Morskie plans as they are not always right & the same goes for the BOGPs. right now i have over 140 sets of BOGPs saved on my computer both complete & incomplete.
i would not start detailing the deck til you have the hull work done as things tend to break off due to manhandling. what are you going to use to buildup the lower part of the bow, plastic, putty or both? why did you replace the original hull sides above the torpedo bulges with sheet plastic, is it because of the gun casements? the top sides of the Pennsylvania class torpedo bulges are shaped differently compared to the New Mexico class bulges. look at this Arizona midship cross section in this link http://www.researcheratlarge.com/Ships/BB39/BOGP/RG19_ALPHA_Arizona_BB39_09.jpg & compare it to pg 35 in the Profile Morskie plans.
