AFTER SOME BAD EXPERIENCS WITH TO THIN PLANKING I GO TO A THICKER PLANK TO LEAVE ROOM FOR SANDING SCRAPING ETC THAT IS THE WAY I GO FROM NOW ON. GOD BLESS STAY SAFE ALL DON
I do understand your point. Yes, knowing how to properly use a plane is fine, but for many of us there are other factors. If the plane is cutting fine, then jams and tears the wood, damaging it, it's too late to change direction. Kits often provide wood that has wavy grain direction. A thin 0.5mm strip of wood being planed on its edge often bends to one side and breaks along the grain. It's delicate. Repositioning how far the edge of the strip protrudes from the vise 100 times to create a curve and using a plane takes quite a long time. Suffice to say, there are other methods besides the traditional method of using a plane.If the grain tears then you are planing in the wrong direction. If the grain changes you are using the wrong piece of wood. You cannot plane wavy grain at scale. It is very difficult even with for 3/4" stock.
Hi Phil, I use the same Veritas plane - expensive here @ £40, but a brilliant little tool.I've had great results planing thin planks (1mm, 2mm) using a jig and a small block plane. View attachment 295737
Con una lijadora y papel de grano 800I've had great results planing thin planks (1mm, 2mm) using a jig and a small block plane. View attachment 295737
Back in 2020 (or thereabouts) there was an article in the NRJ on how to build a "`"sanding box" (build it out of scrap wood) to be used with a sleeve sander (purchase at Harbor Freight for about 7 bucks) in a drill press. If you build the box carefully keeping minimal "space" between the top hole and the sleeve, use the finest grit sleeve, use a slow speed on the drill press, have lots' of light so you can see what you are doing, suck the sawdust away with a vacuum cleaner and make copious width measurements with a good MANUAL (non-battery operated) dial caliper that measures to 0.001" (amazon.com for about $25), you should be able to create any curve (or taper) in a 0.5mm (0.002" thick) plank that you can draw. I have been using mine for about ten years (before the article) and have tapered thousands of planks in the thickness range 0.5mm to 9mm and width range 0.06" to 0.33". This is the easiest, quickest, most versatile and accurate method I know of. You can taper almost any plank in a minute or so (without breaking the wood) to a tolerance of +-0.001" in any length from 1" to 36" (the range of my planks thus far). Good luck.Does anyone have some suggestions on finish hull planking strips that are .5mm thick how to taper the planks?? especially you guys who built the La Soliel Royal looks like a pain?
Sanding .05 (.5 ?) planking really starts with very precise fitting of the planks as they are applied to reduce sanding requirements. Then, light sanding is all that is necessary using a fine grade sand paper. In my experience one of the advantages of .05 thin planks is that it is actually easier to apply with more precise edge fitment. I have not experienced needing to sand down .05 thin planking to a point where it sands through to the first layers.Great discussion on planking I still feel uncomfortable using such thin planks not just because of the shaping of the planks but also the sanding .5mm could be unforgiving!! So I decided to purchase 1mm and give me some room to breathe and also upgrade the finish planking material Personal preference I guess!
