Airfix Golden Hind 1/72 with added rigging and details
Good day,
Fully agree with DAFI regarding position of FM - it was quite usual for that period(end of 16th begining of 17th) to place fore mast here, for me seems smthg wrong when I see for this period and type of the vessels they try to place fore mast on the FCstl deck thus making incredible mess with rigging here on such limited/narrow space ( as most of the 16th galleons had )...
I faced this issues personaly in the past when assembling spanish galleon model... and I liked this AirFix kit 1:72 for they did it historically correctly ...
look at this autentic pictures as example of FM location before FC forward bulkhead ...
All the Best and happy NY 2026!
The_demise_of_the_Spanish_Armada_-_Classis_Hispanica_celeberrima_quae_anno_celeberrimo_MDLXXXV...jpg
William Bourne (c. 1535–1582) A regiment for the sea. Source Created or Published 1592.jpg
more intersting details of the rigging You could find here , on this famous ElJonas galleon model, consider as dafi said absolutely right "... All models of Golden Hind or Revenge base originally on that MB drawings, having the flaws added later. And as you look to seek for the best interpratation, also do not look at replicas or modern models, they are just as good as the knowledge of the builder was...."
Dafi, Kiril4: thanks very much!
In my mind I have stopped referring to the "corrected Airfix" location and will henceforth refer to it as the "alternate" location.
And I agree - I will put it where Airfix suggested, before the FC. It will be another point of difference between this ship and later ships..and hence part of the reason for having different models!
Many thanks!
Many thanks!
this is getting SO interesting.
As regards the hand rail question though, the picture of the inside merely demonstrates how old the tooling is - back to the days when moulds always had the ‘inside’ flat to save expense and complexity.
Ask yourself if you intend to paint it, and if so go the route of adding a strip to the inside and filler/abrasive to give a smooth top surface.
As to the foremast - as we said previously, there is no factual evidence, so you are making it the way you choose. Put yourself in the mind of the shipyard master, knowing what they thought they knew about ship design, and decide where to place the mast.
Exciting !
J
Thanks Jim....the inside strip seems to be fairly safe from producing a large error, and is not too fiddly. I will either go with that or just paint...simplest but not as good. I will report back. SPending the next couple of days removing gun ports and making shutters for the windows!
Oh - someone (I forget who, but it was probably in a SoS forum on the GH) recommended the Anatomy of the Book on the Susan Constant. I have been reading that too. Very similar ship, similar period. It has the foremast at the very far forward part of the forecastle. It is a useful reference!
So to add further to the confusion...Eugen's plans show the mast through the forecastle also...
Good day,
As I remember Eugen did his GH reconstruction by motife of R.Aker's GH reconstruction , but R.Aker placed fore mast penetrates trough fcstl deck / but , You could ask him-Eugen directly, why he did it like this? ...
In common, it is very strange for me - on most contemporary pictures it is clear seen that fore mast, as a rule, placed in front of forecastle beakhead bulkhead and only in few cases we could find it went trough forecastle deck , but modern reconstructors /designers all as one prefer to place it passes trough forecastle deck ... I don't understand why...?
Not that this is any pretence of accuracy, but yesterday I had the TV on, showing the Pirates of Caribbean one with Blackbeard. The ships that were reconstructed and CGI’d were about GH period and design, with foremasts in different places.
Hollywood is known for historical accuracy of course, (ahem) so I suggest that their pictorial evidence can be regarded as the absolute truth. (Cough)
J
I am still trying to decide where to put the foremast! But in the meantime I have opened out the gun ports and made shutters for the upper deck windows. They will look like shutters when painted with hinges etc. I hope.
Hollywood is known for historical accuracy of course, so I suggest that their pictorial evidence can be regarded as the absolute truth.
J
The "different places" might be more accurate than we think :-) Seems this period was about the time of the transition from before the forecastle to through forecastle?
Maybe I am nuts (this is certainly possible) but I cannot see the foremast in any of the pictures. There is one where it is blocked by a sail...
Good day,
Yes , correct , in these pictures You will not see it, and this model has fore mast inside forecastle ( there are more other pictures of this model in the internet where fore mast good visiable)... I mentioned Elizabeth Jonas galleon model as good source of information of galleon rigging , in my opinion , they did it very nice!
I am immobilized by indecision!!!
Nonsense, you’re merely weighing up the merits of the differing arguments for the historical design of the ship, perhaps at different periods, or because they altered the rig, or you are considering the most likely way a builder of the place and period would be most likely to have built it.
Yes, that sounds much better!
Same result though :-)
I have also been thinking about the beakhead. Airfix provide a solid piece with planks moulded into it:
I also have the HiSmodel wooden deck to overlay. It has holes between the planks, as it should have.
This veneer deck needs the structure of the plastic underneath but .... to see through it would require removing lots of plastic planks and they woud need to be precise and square and... I think that is a disaster waiting to happen. But I noticed that the piece underneath has the horizontal spars that match up with the veneer deck...you can see here, the light comes through the thin part but the horizontal pieces align with the horizontal pieces in the plastic and veneer deck (shown in white on the right)
So I plan to remove the plastic between the horizontal spars (brown, left figure below) while keeping the outer frame for solidity.
Then glue the veneer deck onto the frame and it should be strong and also enable one to see through the beakhead. And I think this is easier to do and less likely to result in a catastrophic accident!
With the hull undercoat done I will start the final paint job. Gloss white below water. Here is my plan for the painting. I will preserve the geometric patterns but avoid the brighter colours.
I tested various paints and then painted (crudely!) a mockup with the selected colours:
Blue = Humbrol 89
Red = Humbrol 73
Yellow = Humbrol 7
I think I might actually make the blue a mix between H44 and H89....to make the blue a little duller.
The brown was a rattle can of Tamiya Nato Brown TS62.
For the rearmost bulkhead ...
...I have decided to open the windows and add glass. A mockup seems to work OK. This was clear plastic, scribed and then a black panel liner added. If done more carefully, I think it will make good windows.
Then I have to add a small dark room on the other side!
It should end up looking someting like this (but different colours)
