- Feb 14, 2019
MS innovative construction video
visit us at:Web shop http://www.marisstella.hr/model-ship-kits-marisstella
YouTube
www.youtube.com
Facebook
www.facebook.com
Mechnical Overview:
MarisStella's Advanced Hull Construction System
Date: February 16, 2026
Title: Project ManagerFocus
Areas: Research and Design
MarisStella Model Ship Kits
introduce a groundbreaking approach to historical ship model reconstruction through a trio of unique, patent-pending hull construction systems. Each system is engineered to address specific modeling challenges, prioritizing structural integrity, precision, and ease of assembly.
Core Assembly Philosophy Across all three systems, MarisStella employs a consistent and meticulous assembly protocol:
1.Dry-Fit Assembly:
All structural components are assembled without adhesive first. This allows for multiple checks and adjustments to ensure perfect alignment and a square hull.
2.Delayed Adhesive Application:
High-quality wood glue is applied only afterthe entire structure has been verified. The adhesive is brushed liberally over every joint, wicking into the connections to form an exceptionally strong bond.
3.Laser-Cut Precision:
All framework components, excluding solid wood battens, are precision laser-cut. This guarantees consistent fit and eliminates the need for tedious manual fitting.
System 1: The Heavy-Duty Monocoque Framework This system is engineered for maximum durability and resistance to handling stress. It is the ideal foundation for large-scale or complex models.Structure: A solid wood keel serves as the backbone. Laser-cut bulkheads are slotted onto the keel. The defining feature is the integration of thick, round wooden battens, which are threaded through pre-cut holes in the bulkheads.Performance: The resulting structure is an incredibly rigid "monocoque" (single-shell) framework. It is designed to withstand the heavy physical loads associated with intensive planking, sanding, and rigging work, preventing warping or structural failure.
System 2: The Interior-Ready Hull Designed for models that will feature a highly detailed, visible interior, this system prioritizes a clean internal structure.Structure: Similar to System 1, it utilizes a solid wood keel and slotted bulkheads. However, the design focuses on creating a cavity ready for interior finishing.Stabilization: While the initial framework is precise, it achieves its full operational strength only after the application of the inner planking (the interior hull lining). Once the inner planking is secured, the structure becomes a solid unit, ready for the installation of decks, furniture, and other interior details without risk of flex.
System 3: The Visible Frame (Barge) Construction This specialized system is tailored for the reconstruction of historical barges and vessels where the internal frame structure is a key visual feature.Structure: The laser-cut bulkheads are designed to represent the authentic internal frames of the vessel once construction is complete. They are mounted on a solid wood keel.Application: This framework is intended for hulls that will showcase the elegant arrangement of the frames alongside a detailed interior. The structure is finalized and stabilized by the application of the outerplanking. The external skin locks the frames into position, creating a display-ready model that accurately depicts the vessel's construction methodology.
Order here: marisstellamarisstella@gmail.com
PayPal Account: marisstellamarisstella@gmail.com
We also accept payments through our legal bank accounts. Feel free to ask.
MS Model Ship Kits
YouTube
Model Ship Kits MarisStella Ltd
The Story of MarisStella Model Ship Kits by MS Model Ship Kits Born from passion on a workbench twenty years ago, the first MarisStella model ship kit was a simple dream. It soon outsold known competitors, gaining serious recognition. The team then committed to becoming the best, achieving...
Model Ship Kits MarisStella Ltd. 2,272 likes · 33 talking about this. The Story of MarisStella Model Ship Kits by MS Model Ship Kits Twenty years ago, a small model ship kit was born almost by...
Mechnical Overview:
1.Dry-Fit Assembly:
MS Model Ship Kits
