On my 21st birthday I reported aboard the schooner Pride of Baltimore as a deck-hand and gunner. Five years before, my first paying job was on the construction of this very boat.
I spent nearly two months on board Pride and a year later acquired a set of plans from the designer, Thomas Gilmer, with the intent of building a working model.
I started that model, straight from the 1:32 scale plans, while I was living with 7 other people in a big Baltimore townhouse. That model, only forms and half planked was destroyed by a room mate while I was away on another boat.
I started this model much later, when I was single, "owned" my own home, with a workshop out back, you know "settled down" for the fourth or fifth time. I moved here in 2008 and resumed working on Constellation in 2009, but progress was slow on that model, so I figured a schooner would be quicker to finish and net me something to sail in the nearby creek.
I often think this way, and these ideas often don't pan out they way I hoped.
In 2010, I started by re-scaling the plans to 1:36 scale to match my model of Constellation, but this seemed to small to fit servos and mechanics strong enough to control a relatively huge amount of sail. I decided to scale her to be about the same size as Constellation over the rig (tip of bowsprit to tip of boom), or as big as she could be and still fit in the SUV. What I wound up with was 1:20 scale which would give me:
This drawing is a reduced version of a work-in-progress. The actual boat was different than her plans in many ways; hatches, the stern, deck arrangement, etc; so using images from my time on the boat, other images from that time-frame I find, and Greg Pease's book Sailing With Pride, (ISBN:0962629901) this "plan" will become the most accurate set of exterior drawings of the boat as she was in the Fall of 1981.
* remember that you can click on the attached images to see larger versions.
This build log is NOT about the Pride of Baltimore II, but the boat that preceded her; here's a quick history of the original Pride of Baltimore.
- Hull length: 54" (137.16cm)
- Length on deck: 48" (121.9cm)
- Length on waterline w/o rudder: 46.75" (118.75cm)
- Length over the rig: 81.5" (207cm)
- Beam: 13.625" (34.6cm)
- Draft without external ballast: 5.875" (14.9cm)
- Total height (top of jack-yard to bottom of keel): 61.6" (156.5cm)
- Total Sail area: 2,205.13 square inches (14,226.6 scm) in 8 sails.
