This is my first thread posted in this build log. I took a 30-ish year hiatus from ship and boat building to work on my model railroading hobby. I now have a completed model railroad layout. During that time, I did build a few ships and boats to incorporate into the scenes but they were all water line models. (I posted a few photos in another thread.)
I thought I would ease my way back into ship building by completing a boat I intended to build back in the early 1990s: a Beachcomber Alpha Dory in 1/2":1-ft scale. I used the offsets from John Gardner's Dory Book. I used my old drafting set from high school to complete this drawing:
After photo copying the drawing, I started construction with the bottom and the centerboard/box assembly:
Because I like to complicate things, I made the centerboard operational:
The bottom will be cut to roughly the layout lines. I will leave some room for shaping:
To build the frames I constructed a fixture from sheet and strip styrene. I used plastic so the yellow glue used for the wood would not stick. I realized later my mistake. The frames should overlap at the bottom but I built them as one piece. The cross brace at the top will be glued the the base board. The center cross brace is to mark the shear plank. Here is the set of 6 frames. I later realized my second (of many) mistakes: Frames A and B are only to help shape the hull and are not frames. Also, I should have cut or bent some of the frames. Oh well....
Next up: combining the frames with the bottom and on to planking.
Pete
Pete
