- Dec 3, 2022
The time to incorporate stealers was rapidly approaching - to my horror. On my first boat build I had simply narrowed a plank to a long sharp point which sort of worked but was neither historically right nor very strong. This time I wanted to do it right.
This was my guide diagram from Zu Mondfeld's Historic Ship Models. I had no idea how to achieve this result and decided not to look it up because I'd enjoy working it out for myself. I was unusually careful however, and experimented off the boat, with some scraps.
That was the easy part. I hadn't narrowed the end of plank prior to cutting the end at the 45 degree point. This experiment was where I learned that it would be necessary!
I placed the stealer on the other planks and drew around it.
I cut the waste out with a piercing saw.
And tidied up with files.
Not bad.
Three strakes became two. This was quite encouraging.
I had used CA which carried some of my pencilled markings into the grain but apart from that I was delighted with the joint.
See how the outer planks are curving outwards? I thought about shaving their mating faces so that the entire assembly would loses more width in an elegant and gradual way.
This was the second experiment. I had abandoned the sawing and filed the joints instead. It was more efficient that way.
Note that the three planks now have straight lines at the outside for mating up with the rest of the hull planking.
The third test involved reducing the width of the centre plank before making the joint.
So this is where the shipwright says, "We are getting close to half width here, better make it a stealer." Of course in 1/1 scale HE can chop out a recess in the plank above even after it's 'nailed' to the frames.
I was a bit bored by this time so test three is rushed but I think it showed that reducing the outsides of the centre plank and the inner sides of the outer planks together makes a nice steal. I planned not to take as much from the centre plank as in the test though - I wanted all three planks in the area of the joint to have the same width. Just because.
So now I was an expert! Hahahaha!
Time to try it for real. Twice.
Marking is vital. It's very easy to glue them on the wrong side upside down and inside out. I also marked the hull to match so that I will perhaps notice any screw-ups.
Sure enough, there I go measuring the starboard plank against the port hull. That was not deliberate and as it was only for the photo shoot it didn't matter, but I had to laugh when I just noticed the error.
The photo was supposed to show you that I'd cut the stealer to lie over a frame so that It would be strong when it was done, just like the real ones.
This is how I do the marking out. I use two planks underneath to stop the upper one from falling off. I line up the midships arrows - roughly is good enough, there will be some fore and aft adjustment later on. The pointy plank END points to the edge and seven cms back the EDGE of the pointy plank crosses the edge of the one I'm marking.
As I took this pic, I realised that I hadn't tapered the pointy plank. So I started over. That's why I work in pencil.
I filed a taper on the pointy stealer, reducing it to 2/3 of its original width over about 7cms.
When the flanking planking was remarked (top plank) I was happy to note that the blue line is about 2/3 of the red line. This should mean that the three planks will all be 3.3 mm wide at the join, or 2/3 of a plank width.
The bottom plank is the first, mistaken marking and you see that the cut out would have been HALf a plank width if I hadn't caught the mistake. An error of 0.83mm would have ruined the symmetry and been very upsetting.
Things don't always fit first time. This is ok as I can recut, and shift the planks fore and aft to compensate - once. After that I'd have to start again as the long side would increasingly be the wrong shape. I have many planks but limited patience.
Still poor but I decided it was good enough to continue with this first attempt. (That was a poor decision)
And there we go. Not glued, just clamped for the photo. Only one side prepared. Not yet bent, not yet cut to length. Not yet glued onto the hull. Time elapsed? I thought it had been 20 minutes but when I checked the clock, I'd started at eight and it was five past nine. An hour and five minutes had slipped away unnoticed. Everything about boats takes twice as long as I expect. When time just ceases to matter like that, I know I'm really having the best fun!
The chopped up plank, now narrowed at the back as well as the front, was just waiting its chance to snap on me so it was very important to wait until the bending iron was really hot, otherwise I knew I'd tend to use too much force before the wood had softened. As I come lower down the hull sides there's less bending to do and it soon took the shape I wanted.
That plank went home easily. I expected no difference because the complicated stuff was on its lower edge. The middle of the three planks went on with little in the way of preparation but the fit at the joint was awful. I chiseled away at it as much as I dared and ended up with this.
Not only were the first two planks a poor fit but the third one wouldn't locate at all. It didn't make sense. the top and middle ones had a gap and I thought that should make the joint with the lowest one tight at the three-plank point, but the tightness was in front of it. (I'm probably not describing this very well, sorry.)
Not bad.
