Bowling ball clamp jig
And a piece of wood for the table, you can make this whatever size you like, you drill through the wood into the ball, then enlarge the holes in the ball to accept wall plugs for the screws to go into, when you have screwed the table part to the ball you might want to reinforce the under side of the table with some car bog filler, as in photo.
Shows the table top I used and the fixing screws
Make sure when you fix the table it is just above where the Dowell handle will go so you will have lots of positions
to turn it to, see photo. Use a dowell that is a tight fit, you can glue it in if you want.
These next four photos show the versatility of the table, you can fix a vice on it if you want, or just clamp the items you want to work with, its really adaptable. I have .
just used double sided tape to hold the boat
View attachment 26429View attachment 26430
NEVER in my WHOLE LIFE have I seen such persistence and devotion to the art of model hull construction. Such INSPIRATION! You NEED to market that... SERIOUSLY.
