I’ve been watching several Step by Step videos by OcCre. The builders use contact cement on second hull planking and deck planking. The standard technique is to apply to both surfaces, wait about 15 minutes, and then press to place. So far so good. My question is that in the application of the ‘larger’ piece such as the hull or false deck, more area is covered with cement than can be immediately be used by the covering materials i.e. hull strips or deck planks. If the task in question is not entirely completed at one setting, does the cement on this ‘extra’ area need to be removed from the base before starting again? Can you come back the next day and begin again by just applying cement to the new plank piece, do you need to apply a thin coat to the previously dried base first? If you do have to completely remove and start over as you would with white glue for instance, what’s the best method? And is ‘contact’ cement the same as ‘rubber’ cement? I like the immediacy of contact cement over white glue for these areas and it seems to be much more forgiving than cyanoacrylates, but I don’t know how careful I have to be and what the pitfalls might be.
