- Aug 16, 2019
this one will close my ST project Ship, Launch and now Section
Santisima Trinidad OcCre kit #16800
Cross section of the Santisima Trinidad at 1:90
I start that kit in Mars 2004 and I was to do this kit simultaneously with the ship himself but as my older son want is ship to be the red 1805 Trafalgar version with copper hull I decided to build the cross section now and to built it as he want is ship, that way he will be able to decide if he like it or not. But as I got already 2 ships in constructions I will work on it occasionally only until I finish at least 1 of the 2 that are in their final step.
Ok lets start
First the box and the instruction
P 1-1, 1-2
This is my second OcCre build and the box and the instruction are of the same quality of the first. The wood are well package and of very good quality the instruction come in 3. The first is a color booklet in 76 steps guide you for the build of the frame plus 2 more picture for the deck finishing and the mast. The second is the multi language book that follow step by step the color booklet (small note about the one that I got whit my kit was missing the French portion of it but I got 2 time the English one). The third is the scale drawing for the mast and the rigging.
Step 1 Is the build of the frame and went like a charm without any problem at all the instruction are clear and easy to follow
P 1-3
Step 2 - 4 The beginning of the interior lining
Step 5 - 6 Is the pose of lower decks beams and bottom beam rests here I did some modification as you can see on my picture 1-4 to 1-6 you will see that if I place that beam the way the instruction request I will have a small gap. So as per picture 6 I did small indentation in the beam and picture 7 is the result
Step 7 – P 1-7 Is the finishing pose of the inside lining and the columns
Ok lets start
P 1-1, 1-2
P 1-3
