Cutty Sark Mantua 1:78 Build Log [COMPLETED BUILD]
Hi shipwrights,
I’ve just installed the parapet supports, a brass part included with the kit. And i’m so doing, immediately ran into two huge snafus: the supports did not fit, either vertically or horizontally according to the positioning shown on the plans. I backtracked to find out what I’d done wrong and found I’d followed the plans exactly as shown (and written, in the case of their “horizontal’ fit).
I won’t dwell on this, since this is an early 90s kit and I presume they (Mantua) have corrected these ridiculous, egregious misleads in later updates of the Mantua Cutty Sark. I wound up cutting the supports to fit under the parapet ledge, knowing they’d be fairly well hidden behind other components and superstructure...
But yikes, y’all! This Mantua kit has been a lesson in how to deal with inadequate attention to competent plans and instructions, especially compared to the superb experience I had with my first build, done by Atesania Latina.
pictures to follow.
Hi All,
I've been spending less time on the Cutty Sark build lately, due to life, family and holidays. But I've made some progress.
I've constructed and installed the deadeye {chain-wale?} brackets that are located inside the hull on the Cutty Sark.
The Fancy Cutty Sark stern emblem did not fit the contour of the boat as I finished it. But I was somewhat able to make it fit by heating it to cherry red with a propane torch and bending it slightly, in a trial and error process. Mostly error. Plus the tips broke off; the "brass" parts were mostly pot metal and didn't like bending. I just glued them back together.
As I've stated before, this kit was probably assembled in the mid-90s, and I've found a couple of other Cutty Sark /Mantua 1:78 kit builds on the net, and many of the parts on these (I assume) later-built kits had different, probably improved parts. And instructions. I'm still bummed that the "gunport" openings, the parapet supports, plus even the overall main deck layout had skimpy instructions, that, even followed carefully, do not result in proper placement of later parts: the "gunport" did not follow the deck properly (the should have all been flush with the deck at their bottom), the brass pre-made parapet supports were not made to follow the level of the rails--they were too tall in the mid-deck area and too short at the bow and stern ends. I was able to modify them enough that they shouldn't be noticeable in the final analysis of the finished model.
Perhaps I've spent too much time complaining about the kit. I haven't found anything I couldn't overcome. But I think these blatant issues should never have made it to a commercially available product, at it's original price point.
Anyways, here are some pictures of the current state of Sid's Cutty Sark. Hundreds of hours in, many many more to go.IMG_0691.jpgIMG_0713.jpgIMG_0714.jpgIMG_0715.jpgIMG_0681.jpgIMG_0682.jpgIMG_0684.jpgIMG_0686.jpgIMG_0690.jpgIMG_0710.jpgIMG_0717.jpgIMG_0718.jpgIMG_0719.jpgIMG_0691 (1).jpg
Greetings Shipwrights,
I'm finished with the first hull planking of my second ship build, the aforementioned Cutty Sark.
This kit is older, probably made in the early 90s; differs from Mantua's current version in several aspects, as I've come to learn.
I'll begin with pictures and description up to the current stage of completion.
This was a fairly straightforward build, despite the very sparse instructions included. I would absolutely NOT recommend this model for first-time builders, even with my own limited experience. The written instructions are thin, and the plans do not include English translations (from Italian). I used an app on my phone to translate the notes on the drawings and wrote them in English next to the Italian ones. They do turn out to be fairly important!
So far, everything's gone together well.
Keel and bulkheads: all fit extremely tight. Laser cut, very accurate, but I had to sand every joint to enable them to be joined.
Hull planking: very good. The 1.5mm thick "Beech" first layer planking was very supple and bendable, even after decades of waiting to be put together.
View attachment 117949View attachment 117950View attachment 117951View attachment 117952View attachment 117953View attachment 117954View attachment 117955View attachment 117956View attachment 117957View attachment 117958View attachment 117959View attachment 117960View attachment 117961View attachment 117962View attachment 117963
Hallo @Sid Barras ,
34D7D05E-A5DE-47E6-A51A-B1D128B6C0A8.jpeg9F776E62-8C8D-4A8F-9828-D0AB88B33E60.jpegHere, three years later are some photos of the work I’ve done on the cutty sark. As I reintroduced myself and the long delay issues in the intro, I’ll skip that here. The only other mentions are: I’ve added some fictitious portholes, and included a crew member who’s made at an actual 1:96 scale, to show how out-of-scale many of the components of this Mantua kit is. This is a kit made in the 80s or 90s. Don’t know if it is still made, or if so, the components made closer to the 1:96 scale it claims to be. Still much work ahead, regardless.7E8BFE68-8352-409B-AD6B-B97AEE5338B9.jpeg055FE060-CD55-4E3D-9DCF-D02CEBA980E1.jpegE0F11CE9-DD68-4F19-BB15-6BFC099C6B0A.jpeg055FE060-CD55-4E3D-9DCF-D02CEBA980E1.jpegFE8278F0-7CBB-49B9-ADD3-702777D837AF.jpeg12207C56-771A-458C-8437-793267F0DAB2.jpegCAC0F33A-E961-4081-A293-D53087F094E0.jpegA4378A67-365F-4C3D-AEE5-DF842859E0BD.jpeg5F986A4E-ECCF-4A73-B58C-AF2009784514.jpeg2F1D8C94-A1E9-44BB-BC31-F393CD957A6E.jpeg071E9B52-753D-4909-8766-6B16ECE4EA02.jpeg0CF708DA-8802-45BD-BE23-C5CF9D0A39A4.jpeg
Hello shipwrights. I have made more progress on the Mantua Cutty Sark. I think i’m up to approximately 600 hours now. Yikes. But without a lot of fancy time saving tools, that’s life. The masts, bowsprit and yards are now individually assembled, save for the rigging blocks and such. Relying on 40 year old Italian drawings with only a minimum of translated written instructions, I’ve done quite a bit of ad-libbing. I decided to solder most of the parts that were meant to be “riveted.” (The instructions showed taking brass pins and “crushing” the ends with needle nose pliers to hold the parts together, simulating a rivet). That did not work at all! I still need to ‘age’ the brass parts, which I should have done prior to installing but I’ve already tried carefully painting the aging chemical on and wiping off, and it works ok. Soon to start rigging. 4DBEC846-A179-468F-849B-53C4F0E83F65.jpeg5556607C-100C-4A7A-9B45-D7A7691B8C27.jpeg
Hello shipwrights. I have made more progress on the Mantua Cutty Sark. I think i’m up to approximately 600 hours now. Yikes. But without a lot of fancy time saving tools, that’s life. The masts, bowsprit and yards are now individually assembled, save for the rigging blocks and such. Relying on 40 year old Italian drawings with only a minimum of translated written instructions, I’ve done quite a bit of ad-libbing. I decided to solder most of the parts that were meant to be “riveted.” (The instructions showed taking brass pins and “crushing” the ends with needle nose pliers to hold the parts together, simulating a rivet). That did not work at all! I still need to ‘age’ the brass parts, which I should have done prior to installing but I’ve already tried carefully painting the aging chemical on and wiping off, and it works ok. Soon to start rigging. View attachment 356135View attachment 356137
Good evening Sid. Beautiful model. Cheers Grant
Bonne journée, mes collègues charpentiers,
I've made additional progress on the Cutty Sark.
The boat is finally down to only rigging, except perhaps for the inevitable 'punch' list, for instance, I'm dissatisfied with the lifeboat/launches' tie-downs. One thing I've not been able to resolve is the mounting of the anchors. I can't find any images of the anchor on the boat at sea detailed enough to make out whether the cathead is involved in the anchor's stowage and deployment, and the Mantua kit is remarkably silent on actual mounting.
Mercredi Soir, deux mois plus tard...
I've made additional progress on my Mantua Cutty Sark model. Still a bit to go on rigging, and everything gets harder and trickier. I did try to work from the center outward to avoid having obstructions, but not always possible.
This model is way more a craftsmen model than mine is. My later model is easier but this model has a very fine look to it that just says "expert" all over it. You did a very fine job with this and I know you learned a lot from the kit too. I'd like to ask you and all our readers how do the davits get the life boats to the edge of the ship and into the water? They look too far away to me and way too spindly for the weight. No matter what, this is a beautiful model that you should be very proud of building.
Hallo @Sid Barras
Are you working in moment on another project?
