I suspect everyone that uses it has their favorite. Try a few to see what you like best.
Bondo, ,Minwax, Durham's Rock Hard Water Putty, Elmer’s ProBond, and MH Ready Patch are a few common ones. IF you get the planking tight, which is really good practice before starting the second layer, fillers are not needed.
A
Thank you for the information.I use Rustin's - a two part filler. Works well and smooths down very well.
You're not confused. Trust your own judgment!I guess I am still confused about why and when two layers of planking are needed. As AllanKP69 stated above, if the first layer of planking is tight, you may not need filler. But if the first layer of planking is tight with no gaps, why is there even a need for another layer?
Seamus
