- Jul 27, 2021
French Longboat - 36 feet - Scale 1:24, Made by Unicorn Model
Company: Unicorn Model
Kit No: -
Retail Price: $199.-
Available here: https://drydockmodelsandparts.com/products/36ft-french-longboat-1-24-pearwood-version
Description
The French longboat was one of the most versatile and indispensable craft carried aboard a ship. It served a wide range of functions, including transporting supplies, moving anchors, fetching water during campaigns, landing troops in coastal operations, conveying officers and distinguished passengers, towing vessels in calm conditions, and performing numerous other duties. Because its design evolved very little, the longboat retained essentially the same structural characteristics from around 1680 to 1780.
This Kit is a 36-foot longboat. Such a length was typical of the master longboats carried by first-rate warships of the late 17th century and it remained common aboard 74-gun ships of the 18th century, even as the dimensions of those vessels gradually increased over time.
Technical data
- Scale: 1:24
- Length Overall: 590 mm
- Width: 128 mm
- Height: 388 mm
- Level: Intermediate to Advanced
Kit content
- Various pear wood sheets
- Various pear wood dovels
- The Jig
- Small Photo Etch Sheets
- Brass Wire for nailing
- Various small brass parts
- Brass swivel guns
- Sails
- Rope
- Blocks
- Two 1:1 Plans
- Instruction Manual in English
Gun Addition
- Turned brass gun
- Blocks
- Brass wire
- Rope
All parts of the kit came stored safely.
Pearwood Sheets
The kit contains a generous supply of pearwood sheets, and my overall impression of the material is very positive. Before discussing the quality of the wood itself, however, there are two points I would like to mention.
The first—and by far the most significant—concerns the yellow-orange adhesive tape used to bundle the smaller packages. Unfortunately, the adhesive appears to penetrate deeply into the wood, particularly on the thinner pearwood sheets used for planking. In some cases, the residue is clearly visible on the reverse side of the sheet and has penetrated so deeply that it cannot be completely removed. While this may be less problematic on thicker stock, it becomes a real issue on thin planking material where sanding is not an option. The affected areas are unlikely to absorb oil, stain, or other finishes evenly, which can negatively impact the final appearance of the model.
This issue can be seen in the following examples:
Given the otherwise excellent quality of the kit, this is somewhat disappointing. However, it should be a relatively straightforward issue for Unicorn Model to address by adopting a different packaging method in future releases.
As for the wood itself, I believe the overall selection and quality of the pearwood are very good. The sheets display attractive colour and grain characteristics, and the material appears well suited for a high-end project of this type. Only Sheets No. 9 and No. 21 stand out to me, as I personally would have selected different pieces for inclusion in the kit. Even so, they remain perfectly usable and represent only a minor criticism rather than a serious concern.
The laser cutting is equally impressive. The cuts are clean, precise, and sharply defined, with minimal scorching and excellent edge quality. Taken together, the quality of the pearwood and the standard of the laser work are among the strongest aspects of this kit.
The frames
More sheets
Here you might see why I am not 100% happy with sheet 21
More wood
The planks
And even more ...
The dovels
The parts for the Jig
The stand
