Very interesting how you restorated the hull, John.View attachment 473095
and a few pics showing the glassed hull and me working out the position and fixture of the false keel, I\m still shaping the up front block of wood, the two outside threaded rods are locating the keel into the two tubes Patrick had fixed through the hull and the centre rod is just supporting the arch in the center, once i am happy with everything i will remove it from the hull and cast the lead into the frame work and then permanently attach it to the keel,
I'm quite happy with the way things are going, touch wood,
thanks again for dropping by,
best regards John.
John, you are the master of restoration!
Wow - impressive work
and after applying body filler to the keel piece to blend it into the hull shape, any questions just ask,
Very interesting work. It's good that this yacht fell into capable, skillful
hands masters.
G'day, thank you guys for the nice comments and likes, if I get to the stage of putting her in the water i would like to have it Radio Controlled, but that is awhile away yet, I had previously built a revenue Cutter The Speedy and I just used to have the rudder connected to a servo, but it would be nice to have some control over the sails,If I missed this earlier, please excuse, but since you took the trouble to cast the metal keel, I assume that you intend to restore the model to sailing condition. If so, will you add RC or will you free sail it?
Roger
G'day Bob, I know that originally Patrick sailed the Hooker with only some internal ballast but could only do so in light winds, and eventually when he modified the boat and added the deck with the large cabin he then added the false keel, when i received the Hooker she had the false keel bolted and glued on, I'm not trying to make her into something she is not, all I'm trying to do is restore to the way Pat had her, just to honor his Memory and the Friendship we had over the years, when Patrick was in Hospital we used to talk about what he was going to do to her to to make like she used to be and one of the things we talked about was the false keel, we go to a local pond to sail our boats and that is our main purpose, the enjoyment of seeing them sail, Patrick had several other boats as well and they all had the weight attached permanently in a false keel, I don't know about other builders but this is the way we build them, also it helps a lot when we get to the pond as we don't have to mess around tipping them on there side and trying to fit a detachable keel, these models and there keels can weigh quite a few kilo's, hope this helps you understand why we do it this was,Are you intending to permanently attach the ballast keel to the as-designed flat keel bottom? I'm betting that the original builder built that ballast keel so that it could be detached and the model displayed in a stand in its accurate form. This is the common practice when building high-quality sailing models since they all require out of scale ballasting and depth of keel to stand up to "full size" wind!
Happy Anniversary to both of you! WOW, more than a half Century!! Congratulations!... It was our 56th Anniversary today, we just had a quiet day, lunch at a local Hotel and a visit to the cinema afterwards,
Best regards John,
