HARBOR DREDGE/ KRIS SZKUTNIK
Hi DON,
Your JIG for small boat is INCORRECTLY assembled.
PARTS S2, S3, S4, S5 should be under the S1 element
You follow the instruction. Instruction as in Lego blocks.
and FINAL PRODUCT
YOUR QUESTION ....... IS THE BLACK FALSE KEEL DOES NOT GET REPEAT DOES NOT GET GLUED TO JIG BUT THE FLOOR FRAMES GET GLUED TO IT AM I CORRECT????? YES DON. IT IS CORRECT. :)
OK AFTER 7 DAYS PAIN IN THE KNEE AND ELSEWHERE, DOING SOME WORK AGAIN, NOT GOING TO OVERDUE IT I HOPE, COMPLETED HARBOR DREDGE BOAT JIG, NOTE TOP NOT GLUED FOR REMOVAL. GOD BLESS STAY SAFE ALL DON
OK QUICK QUESTION KRIS DRY FITTING FLOOR OF DREDGES BOAT FRAME NO. 10 DO THE TITS REMAIN ON THE FLOOR OR DO I FILE IT OFF, DO NOT WANT TO MAKE A MISTAKE ALSO TH ONLY PLACE FOR GLUE IS THE FLOOR NOTCH TO THE BLACK KEEL CAN NOT GET ANY GLUE ON FRAME OR JIG OR TROUBLE. GOD BLESS STAY SAFE YOU AND YOURS DON
THANK YOU VERY MUCH KRIS, WILL DO SAMPLE FRAME ON THE DREDGE TOMORROW, AND SHOW PICTURE ONCE I GET A SAMPLE DONE AND SOME CONFIDENCE SHOULD BE OK., THANKS AGAIN FOR HELP. GOD BLESS STAY SAFE YOU AND YOURS DON
OK DONE SOME DRY FITTING ON THIS OH SO TERRIFIC BUILD, HOPEFULLY I WILL HAVE NOT MANY MORE QUESTION TO BOTHER YOU WITH KRIS, HER THEY ARE MY SAMPLE FRAMES ARE NO. 12& 27 REMEMBER YOUR NO. STAR WITH NO.6 WITCH I WILL USE THROUGHOUT THE BUILD THE PLAN SETS IN THE MONO START WITH NO.1,, BOTH 12 AND 27 SHOW FRAME TOPS HIGH THE PLAN SET SHOW THEM SHORT, USING YOURS, BUT JUST WONDERING IF I AM NOT READING THE PLANS CORRECTLY, NEXT PARTS NO. 4&5 ARE THEY LIKE THE WATERWAYS, FINALLY DRY FIT FRAME NO. 12 THERE IS A SLIGHT GAP FRAME FLOOR AND THE FRAME ON THE HIGHER FRAME DO NOT WANT TO MESS WITH ANY DEVIATIONS FROM YOUR CNC MACHINING WITCH IS SUPBERB, SO JUST CHECKING IF I HAVE DONE SOMETHING WRON WITH THIS GROUP AND ANSWERS CAN START WITH FRAMES, AGAIN THANKES KRIS. GOD BLESS STAY SAFE YOU AND YOURS DON
PROGRESS, WILL EMAIL YOU KRIS, THIS IS GOING VERY SLOW RIGHT NOW AS THE ORTHPEDIC DR, SAID I WILL NEED TO BE CONFINED TO A WHEEL CHAIR DUE TO SEVERE ARTHRITIS IN KNEES THEY ARE AFRAID OF ME COLLAPSING, BUT AS ALWAYS JESUES IS THERE NOT AS BAD AS IT SOUNDS LIKE MY CHILDREN SAID ALL I AM DOING IS CHANGING FROM ONE TYPE OF CHAIR TO ANOTHER, JUST SOMNE WIDENING OF 3 DOORS AND REARANEING SOME STUFF AND BACK TO WHAT JESUES HAS GIVEN ME. GOD BLESS STAY SAFE ALL DON
THE REASON I POSTED MY PHYSICAL PROBLEMS IS ASKING FOR HELP IN ARANGING WORK TABLES, TOOLS AT THE RIGHT HEIGHT ETC, ETC ANY AND ALL SUGESTIONS TO KEEP IT GOING IS WELCOME GREATLY. GOD BLESS STAY SAFE ALL DON
A friend in the past bought an old hospital bed, uses just the wheels and mechanica below to make a table that he could raise Electric. He used it to repair his bike. But with an extra layer of drawers it will be high enough to ba a working table. Maybe an idea.
OK FOR THOSE INTERESTED A DIFFERENT TYPE OF BUILD A DIFFERENT TYPE OF SHIP, HOW MANY INTERESTED, LET US SEE, HAVE NOT MADE MUCH PROGRESS LATELY DUE TO SOME PHYSICAL PROBLEMS THEY ARE STILL THERE BUT CAN RESUME SOME BUILDS HOPEFULLY GET BACK TO REGULAR BUILDS HERE IS UPDATE ONE SIDE FRAMES, FLOORS,ETC ALMOST FINISHED, OTHER SIDE SOME DONE HOPE TO START FINISHING UP THE OTHER SIDE TOMORROW ALSO BOW AND STERN FRAMES NEED TO BE DRY FITTED ALSO BTW ALL FRAMES ARE DRY FITTED ONLY AFTER FINIHING WILL INSTALL THE KEELSON, AND OTHER 2 LONGTUDIONAL STRINGERS FOR STRENGTH THEN SOME FLOOR DECKING AND BOTTOM DECKING DOES THAT SEEM RIGHT TO YOU KRIS, FABOLOUS JOB KRIS,. GOD BLESS STAY SAFE YOU AND YOURS DON
Looking good Don! Glad to see that you are back at it!
HI ALL, NEED SOME HELP KRIS, BOW FRAM NO 6 AND STERN FRAME NO 35, HAVING PROBLEMS THEY ARE COMPLETLY DIFFERENT IN SIZE AND SHAPE AND LINEING UP THE FRAME PIECES CORRECTLY, FRAME NO 35 SEEMS CORRECT THE STERN, FRAME NO 6 NOT SO A COUPLE OF PICTURES. GOD BLESS STAY SAFE ALL DON
WELL HERE I AM AGAIN, PROGRESS BEING MADE, ONLY 2 MORE FRAMES AND ALL FRAMES WILL BE DRY FITTED EXCEPT FOR BOW(NO 6) STERN(NO.35) KRIS IF YOU GET A CHANCE PLEASE COMENT IF I AM ON THE RIGHT TRACK, MY NEXT STEP IS TO GLUE THE FRAMES TO THE KEEL STRIP WHERE PINS ARE SHOWN, THEN THE KEELSON ON TOP OF THAT FINISHING THAT PORTION WIT THE STIFFENERS PART NO. 3, MY NEXT STEP I AM NOT SURE OF I HAVE FLOOR AND BOTTOM PLANKING TO DO I WANT TO DO THIS PARTIAL SOME ON THE FLOOR AND SOME ON THE BOTTOM DOES THIS SOUND CORRECT ALSO I THINK I NEED SOME TEMPORARY BATTENS TO HOLD FRAMES IN PLACE TEMPORARLY UNTIL DECK CLAMPS INSTALLED IS THIS PROCEDURE CORECT KRIS, THANKS AGAIN FOR SUCH A WONDERFUL AND ENJOYABLE SEMI/ SCRATCH KIT. GOD BLESS STAY SAFE ALL DON
Ahoy!
@Don - I checked all sizes again. Frames 6 and 35.......... Everything should be OK. You the glue as instructed.
Your elements of the model are in such herself scale as the monograph Ancre (scale 1/36). Use the drawings from the book. All wooden pieces are the same as in the Ancre book. Maybe you need to sand a little with sandpaper?
HI KRIS, MAYBE THIS COULD HELP ME I SHOW PICTURES OF THE 2 WITCH FRAME IS THE LONGER ONE THIS SHOULD GET ME ORIENTATED CORECTLY, SORRY FOR ALL MY CONFUSION. GOD BLESS STAY SAFE YOU AND YOURS DON
