Jeff, sounds like you need some…where should I send 2”? That ought cause your entire area to not move for a couple of days…No snow here in my area of Florida !![]()
No, it would melt off pretty fast. It was 76 deg F today.Jeff, sounds like you need some…where should I send 2”? That ought cause your entire area to not move for a couple of days…
I would look at the you tube channels, there are thousands of videos. I would also look at the model ship world site.Thank you for the welcome. I look at the build logs. I take screenshots of ships that I have kits for. Multiple build logs as each log is different but I figure if I get enough of them I will have it covered. Is there another place I should look?
Greetings! It's beautiful until it has to be moved. I am in Medway, ME, and we usually get hammered. Thankfully not so much this year. I grew up 32' from the high water mark back home, but only got started in model ship building in 2022. This forum has offered a lot of good lessons and tips! Stay active. .. .I started with 1 bench, expanded to 2. Then I wanted one to put painted items to dry. This has been my RX for RA, to keep the fingers moving!
I have bought pieces parts from Dry-Dock!Welcome aboard!
