HM Armed Cutter Alert (1777) - Vanguard Models - 1/64
Your discoveries and observations sound SO familiar! Endemic, I guess to the modelling experience!
Your model is developing swimmingly (as they say),
Mr Experience is the best teacher and it seems he works to a consistent syllabus. :)
There are people here newer than I to this business and I see them learning the same things that I did two years back.
My wife suggested everything I do on Endurance, do the side that faces the wall first ROTF ROTF
Well, I was using that principle when I started but I can't for the life of me remember which side that was.
At the end of play today the scoreboards look like this.
The aft end with the rough tree rails in place (but not finished), is pimped up like a Mini (car) with an 'aerodynamic' spoiler. Only the young Master and Commander and possibly his lubberly (ha!) girlfriend will be impressed. It does make the cutter look like there's a quarterdeck there somewhere, but not well enough to fool a French lookout so I presume it's just for show.
Up in the bows the catheads clicked into place very satisfyingly. I was concentrating hard on getting them right. Lately I've been looking at the woodwork of @dockattner with much admiration and now I keep asking myself "Would that be good enough for the Doc?" Usually, I go on to say "Probably not but perhaps he won't notice." ROTF
And finally I applied the almost forgotten 'go-faster-stripe' which would go well with that spoiler on the Mini. I resorted to CA to glue that on and hastened the process by heat setting it with the trusty old plank bender. That tip came from Olga Batchvarov who is a member here I think. Thanks Olga.
That's brought the thread bang up to date so I think I'll toddle off to bed. 'Night all.
I like this boat so much. I was so excited about the idea... I don't remember talking about it. I have a crazy idea to order a kit from Trident and try to make two hulls at once. One is a hull, only frames and beams. And the second one is to make a hull from my own material, plus all the filling that I will take from the set, completely covered with slats. Simplify the hull inside in three places where it won't be visible. But on this hull with the sheathing from Anatomy, take the rigging and spars and even sit the sails and build a full-fledged model. And as a result, install two hulls under one display case. One is just a skeleton, the other is completely assembled. BUT the problem is different. I haven't finished my model yet and I don't have much time at all for all this. But it's like a little dream)))
Modellers - we are the dreamers of dreams!
That sounds like a fabulous idea for a display, the two hulls together.
I have been dreaming up some ideas to display Emma C Berry in an interesting and uncommon way. I won’t say any more now because the plans change so much, just like dreams do. ;)
I forgot to mention the little applicators I use with CA.
I take sewing needles, file off the ends to leave a two pronged fork and mount them in old paintbrush handles, preferably ones that won't roll away across the desk. The fork picks up the CA by capillary action and transfers it very neatly the same way to the joint surfaces. I have different sizes for different jobs but most are too small for woodwork. This is my biggest. When it clogs I burn off the dry CA with a cigarette lighter.
I've edged into two little tasks today.
First, the carving of that finial. The laser cut pieces seem to fit ok, though they are a bit clumsy, I'd like mine to have more of a curve but since these pieces are the right size to meet both ends, they are a good starting point.
I've glued two of the kit pieces to my pearwood stick and will file around them to make a nice shape. This is my first attempt to actually carve something for a model boat so I'm not expecting to get it right first time.
Something that I have done before but strongly dislike is hanging a rudder. I have no idea why as it's never failed or even been difficult. It just scares me. Maybe I'm a rudderless individual who fears being controlled? Ha! There may be something in that.
The method for this rudder is quite clever, I think. Those little swimming ducks PE-34 are both pintles and gudgeons (should be widgeons) and the other ironwork is just cosmetic.
I've used epoxy to fix the brass into the rudder for strength. I realised at this point that I'd forgotten to chamfer the leading edge of the rudder and the trailing edge of the sternpost. It's not possible to fix now that the copper is on so I'll turn a Nelsonic eye to that. It might also have been smart to have blacked the brass before fitting it. My hindsight is remarkable in the new modelling specs.
And that's it for the day. Wednesdays tend to be busy for me, domestically. Perhaps I'll have more for you tomorrow.
My dear readers, do you prefer these daily updates where not a lot happens or would you find it a better experience if I held back until I had enough material to fill a page?
Much prefer Smithy, I look forward to them, not just your awesome progress but also the way it's written.
You have a "way" mate, I keep saying you should write a book.
"Smithies way of putin' wood int' thole" ;) Thumbsup
Cheers Cat. I was never really going to change my ways. I enjoy the writing too much for that. I just wanted a bit of feedback.
The book I was going to write when I left the RAF and semi-retired was a prosopography (I love that word - it means a biography of more than one person) of the members of the Lunar Society. They were an eighteenth century gang of scientists, engineers, book-keepers, doctors, geologists, entrepreneurs, from the general area in which I was born and now reside.
The Lunaticks met at each others houses at the time of the full moon, not because they were crazy but because there were no streetlights and it was safer to ride home by moonlight.
I worked on it for 3 months before meeting up with a famous local historian to talk about making a living by doing that sort of thing. He told me how much he’d earned. Hmm. I got a job soon after and forgot all about writing.
About three years later Jenny Uglow wrote ‘my book’ which became a best seller. I haven’t read it myself, though it’s probably a brilliant read. Ha!
Right up my alley mate, love those sort of books,
I have many weird and wonderful on my bookshelf, normally reading 2 or even 3 at the same time.
Currently reading Yuval Noah Harari, his 3 books "Sapiens" is jaw-dropingly brilliant
I know that one. Writing histories of the world like that is very difficult. They have to know everything! I enjoyed Sapiens but Homo Deus not so much. I think historians should stick to writing about the past instead of guessing about the future, when they are almost always wrong. What’s the third one you have?
Coppering
I was happy with the results of my plankings but keen to get the copper in place to hide the worst of it. There's no provision for coppering provided in the Alert kit but it's known that it was done and I wanted to experiment. I'd coppered a model once before, with self-adhesive foil, so I knew the layout, but this time I chose to use some copper sheets made for the purpose by Amati. They were 0.1mm thick and very hard and springy. They were also shiny. Patrick O'Brian, C S Forrester and suchlike authors often mention the beautiful shining streaks of copper showing at the waterline of a ship heeling to the breeze. Clearly they were off school on the day they should have been taught chemistry. Copper in seawater doesn't keep its shine for long, and I suspect that 18th century copper straight from the foundry wasn't particularly lustrous. It was likely to be contaminated with many different compounds which would all react quickly with salty water to produce some marvellous colours - and a lot of brown.
To kill the shine, start the reactions that I wasted to simulate and soften the plates, I annealed the large sheets of copper before breaking them into individual sheets. That's a simple matter pf heating the metal to red hot with a soldering torch and letting it cool slowly.
By heating the sheets irregularly, I found that I could vary the colours. Painting on various solutions of household chemicals like bleach, vinegar, saline before the heating was even more spectacular.
The sheets came with an engraved pattern of circles, meant to represent the nails which held the copper to the hull. I thought the circles were too large, too few and far too regular so I used a variety of sharp tools to impress patterns and random marks into the surface.
A coarse round file was the most useful for general nailmarks. I rolled it over the sheets before separating then into the individual plates, trying to avoid any regularity creeping in. I also coarsely sanded both sides of the sheets for texture and to key the surface for the CA glue.
Each of the 700+ plates were overlapped and worked into place with a ball ended tool. Toolmarks just improved the chaotic, organic appearance of the copper.
Once applied, I gently sanded the high spots. This made the overlapping structure far more apparent and also exposed some fresh copper for the last stage in my chemistry process. I was having such fun - think of a mad scientist, drunk with rum and inspiration. Actually it might have been the CA fumes...
The last stage was to hard boil ten eggs, chop them up and place them in a bowl inside a large plastic storage box with the model. The sulphur compounds that give the eggs their marvellous aroma gave turned some of my copper into copper sulphate and other 'stuff'. (I didn't listen to the chemistry teacher much either.)
This was one of my favourites. There are greens, reds, yellows, black, oranges... Isn't that gorgeous?
After a few weeks the chaos was muted by the general tarnishing of the copper by the ambient atmosphere in a small flat occupied by a single man and his dog. ROTF
This was the best of times and the worst of times. I hugely enjoyed the creative experience of playing with chemicals, fire and sharp things. On the other hand, the exposure to a large amount of CA glue over about three weeks of working was bad news. I was already sensitized to CA so I took precautions.
I had all the windows open, giving a strong cross breeze across the flat. I directed a small fan across my desk with another very big fan blowing the fumes out of the downwind window. I wore nitrile gloves and worked with tweezers. I wore a mask.
I'm glad I was so careful because it must have reduced the damage. However, I still contracted dermatitis with sores on my hands, particularly the right one which was closest to the CA in its little dish (with a cover!) and on my face around my mouth and nose where I'd breathed the fumes in. I looked like a chronic glue-sniffer, which indeed I was, thankfully temporarily. I developed chest pains and a cough too. The sore in my left nostril took a month to heal and bled daily. This is the last time I'll be using CA in any quantity for any reason. It's as nasty as novichok as far as I am concerned.
It was all worth it though. ;)
I am speechless. That looks awesome. Congratulations sir.
Excuse my ignorance, but is that like the Freemasons?
21 Lessons for the 21st Century.
A compendium of topics ranging from Technological whoopsies to Political clowns, Terrorism, Secularism, and a half dozen other isms in there somewhere.
I'm currently reading 2 others of his, not getting obsessed, just randomly bought out of interest.
Nexus and Unstoppable Us volume 1 as well as making my way through a book on time and relativity by Jennan Ismael. ;)Thumbsup
Secret society? No, absolutely the opposite. The Lunar Society were more like us. They were a gang of intelligent mates with an interest that linked them together - the practical applications of science.
It was thirty years ago when I knew all about them but I’ll try to remember some of the big names. Remember this was the mid eighteenth century when industrialisation, urbanisation, capitalism were really taking off. Some historians claim that there was no individual great man who started it all, others said that without James Watt’s steam engine, the Industrial Revolution wouldn’t have happened. My thesis was that it took COMMUNICATION to light the fuse. Groups of like minded people getting together and bouncing ideas off each other. The Royal Society was one such. The Lunaticks were a more informal but immensely influential gang of mates.
Erasmus Darwin was one of the founder members and probably the best physician in the country. He was a doctor to the king. He developed medical science through the scientific application of observation of his patients. But he was interested in the science of everything. He made a lot of observations of nature he was among the 1st to speak of evolution which turned out to be very important because he was the grandfather of Charles Darwin. Erasmus said realised that evolution happened but it took Charles to work out the mechanism of it. Without Erasmus, I wonder what would’ve happened…
Josiah Wedgwood the potter. Josiah applied science to the industry of making pottery. He would make experiments with different glazes different clays different temperatures. Thousands and thousands of them. He is very famous in this connection, but his major achievement was in inventing double entry bookkeeping and running his ‘manufactory’ on sound financial lines. Something we now take for granted but until then no one knew if they were making a profit or loss!
It happened that his friend Erasmus was interested in windmills. And Josiah used one of Erasmus designs for a compact windmill with no external sales to power his pigment grinding mill. Josiah also had many breakages moving his pottery along the poor roads. Erasmus and others of the society had an interest in canals so they financed one to take Josiah’s pottery safely to market. This brought Joseph Brinkley, canal engineer Into their orbit and led to many technological advances.
Another man with a manufacturing business was Matthew Bolton of Birmingham. He worked in light engineering making all kinds of trinkets. His contribution to the century was to realise how effective machines could be for making many thousands of identical items. His work eventually lead on to interchangeable parts and the production line. Matthew is mostly remembered for his partnership with James Watt the Scottish engineer associated with the development of the steam engine. Also a member of the Society. James would have produced nothing very much without his friend Matthews manufacturing genius, and financial backing.
And so on…
There were about 20 members altogether and if you make a chart connecting each one to the other members whom he helped you end up with the network of influence which I believe was hugely important in the genesis of the industrial revolution.
Oh dear, I’m getting interested in it all over again…
Is the Lunar Soc. mentioned in Unstoppable Us, I wonder?
