Jayne Mansfield, Hawse Holes and a Good Sturdy Tiller
I haven't only been going crazy today, I've re-motivated myself and worked some wood. I haven't had that much time between my other commitments (napping, reading a novel, playing with the dog, walking the dog, feeding the dog, apologizing to the dog for going out to the shop and so on...) but despite that I've made three
strides baby steps forward - three!
First, there's a very dusty port side finial to accompany Marilyn. This one's a bit more bulbous at the front so she is Jayne, for the lovely Miss Mansfield.
I said they wouldn't be a perfect match but would you rather have two Marilyns, two Jaynes or one of each? I love them both.
It's good to have your workpiece held firmly but when this is impossible, I have discovered that it's almost as helpful to put the file in the vice and move the wood. The danger is obvious. When I dropped the carving on the floor, severally, and bent down to retrieve it, I had to be rather careful not to trepan myself getting back up again.
Next!
These were described as 'hawse holes' in the instructions though I think they should be called hawse pieces? I've done a little work on the one on the right. Hawse holes need to have a nice chamfer so that thr cable slips in and out without too much friction or wear. Like the scuppers they were lead lined but in this case to reduce the friction as well as for waterproofing.
There's a name for the sacrificial timber directly below the hawse holes but I've forgotten what it is. [Edit: BOLSTER!] In this case it's the 'go-faster-stripe' fitted a day or two ago. It would be worn by the cable when the anchor was coming straight up so I attacked that with a file as well.
Both together. It's an odd looking design but I suppose the reason will become clear when the anchors are on board.
Next!
At the top is the kit's tiller. It has a twin and these are supposed to be laminated for strength and thickness. It looked a bit weedy so I made the one at the bottom from a piece of spare, thicker fret.
Now I have my little man to help, I can quickly check the apparent size of things. He's actually leaning on the tiller so it would be at about armpit height which is about right? It looks enormous and couldn't be held in one hand like a rowing boat's tiller. I presume two or three hefty helmsman would lean on it with all their weight. It's a short one so not much leverage and it's a big boat with lots of sail area. With that in mind, when I fit it properly, I'll set it a tad lower so they can put their backs into it.
That deadline has definitely provided the necessary kick up the donkey and ejected my from my slough* of despond.
*There's a town called Slough in England. It's not generally thought to be a nice place and in the old days when train toilets carried the warning notice "Do not flush the toilet while the train is standing at a station" it was customary to find pencilled underneath "Except at Slough".
