Great progress and work - Bravo
The Lavery Anatomy book includes quite a detailed layout of the running rig at the spars and masts and has lots of arrows on lines pointing towards the deck but does not have what happens when they reach deck level. I can make an educated guess as to which ropes run through sheave blocks and terminate at the pin racks at the base of the masts but this only covers the heavier ropes.I do not have the details of the Anatomy book about the Bellona in mind, but did Lavery not explain the belaying points detailed enough?
Based on the first post of this topic we know, that you have the book by hand....
Book review - The 74-Gun Ship BELLONA" (Anatomy of the Ship) by Brian Lavery
Book Review: The 74-Gun Ship BELLONA - (Anatomy of the Ship) by Brian Lavery My copy is the original version published by Conway Maritime Press in 1985, the revised version has an additional 1:96 scale fould out plan in the book cover Hardcover: 120 pages Publisher: Conway Maritime...shipsofscale.com
OK - clear and many thanks for the fast answerHi, the brass fittings were all made up and fixed in position to make sure it all fitted together then dismantled, blackened and then reassembled. A time consuming process but it worked.
Cheers
Hi Davide, see if these images can help you.I have started making up the yards before I start the rig.
I will attach as many blocks etc to the yards before positioning them on the mast.
I am having some difficulty with the distance below the yards for the foot ropes. Diagrams I have show the footropes as the same distance below the yard for all of them regardless of the thickness of the yard.
I decided to go back to first principles and research how the foot ropes were used. I found a good video of modern crew out on the yards man handling the sails. This would include bending into place, unfurling, furling and reefing. To carry out these actions the crew were leaning over the top of the yard to work the sails from above and also from the front. The relationship between the footrope, yard and crew was the yard was at about waist level to enable leaning over. A quick measurement showed this to be about 1 metre. The Bellona main yard is about 570mm thick at the centre tapering down to about 350 or so at the ends. Using the logic described above this means the foot rope is only 430mm below the yard at the thickest part increasing to about 650 mm at the yardarm. As the yard sizes decrease the distance to the foot rope would increase to maintain the correct distance to the top of the yard.
Installing the foot ropes like this is going look strange compared to how they are typically done.
Have I missed something? Comments appreciated.
Cheers, David.
f
