HMS Enterprise - 1:96 - 96进取套材的制作
Very good work on the breast hooks - also the bolts are looking very accurate made
Very good work
Great - very clean and accurate work
Will you blacken the brass hinches etc. afterwards, or will you keep the "brass-look"?
铜件可以用化学方式发黑,但我想让它自然氧化,感觉这样会有时间沉淀感
2月中国春节休息近1个月,年后补发一下近期底舱完成的进度
The copper parts can be chemically blackened, but I want it to oxidize naturally, which feels like it will have a settling effect over time.
I will be off for nearly a month during the Chinese New Year in February. I will update you on the progress of the recent completion of the bottom tank after the new year.
感觉前期做的有点粗糙,后面会慢下来,目前开始架设生活甲板的横梁,放一些近期图片
I feel like it was a bit rough in the early stages, but it will slow down later. I’m currently starting to erect the beams for the living deck, and here are some recent pictures.
very good work on the interior walls and also thedeck beams :cool:
Very clean and accurate work. Thumbsup What finish did you use on the wood?
1:96小进取进度更新
生活甲板横梁搭建到尾部时出现累计误差,宽度有3毫米左右,自行加垫块补偿
船体中间部位的横梁加强梁初期套裁需要自行截断,据说后期版本套件已更正
本层横梁搭建完成,开始搭建纵梁,尝试开槽,参考了其它人的制作帖子后,减小了纵梁宽度及抽水机摇柄支架间距,净宽由原来14毫米调整到11毫米
1:96 Small Progress Progress Update
There is a cumulative error when the living deck beam is built to the end. The width is about 3 mm. You need to add pads to compensate.
The crossbeam reinforcement beam in the middle part of the hull needs to be cut off by itself in the initial nesting. It is said that the later version of the kit has been corrected.
The construction of the cross beams on this floor was completed. We started to build the longitudinal beams and tried to make grooves. After referring to other people's production posts, we reduced the width of the longitudinal beams and the distance between the pump crank brackets. The net width was adjusted from the original 14 mm to 11 mm.
生活甲板竖梁完成,用1.5毫米套材内木条打磨炭黑后制作,在横梁上开槽,嵌入安装
中间2条竖梁调整了宽度,为了适应水车
生活甲板不准备做小横梁了,后面会考虑是否加上部分舱室甲板
quick question: I see the anchor point for the mats at the bow and stern... same in the middle? I can't quite see. Down the road, I would like to add mats and some rigging. Looking for a detail set of plans. I think the size will be great for a rigged version (not too big in the living room).
At this scale you are going to have hard time to add rigging
I love a challenge though.... ;-)
By the Way @CTXMM, I'm loving your log and pictures... please keep them coming.
Translation using google:
顺便说一句@CTXMM,我很喜欢你的日志和图片...请继续提供。
Shùnbiàn shuō yījù@CTXMM, wǒ hěn xǐhuān nǐ de rìzhì hé túpiàn... Qǐng jìxù tígōng.
1:进取号继续更新,生活甲板横梁完成,用1.5毫米木条横梁开槽嵌入安装,第一次做开槽,手艺不行45度开斜槽,开槽深度过大,比例失调。 2:进度越来越慢了,一天干不出多少活,完成2部舱底楼梯,把底舱隔板跟横梁补平,没有整料,都是用小碎料拼的,反正在最下面,看不见,另外把生活甲板的舱口完成,随机给舱口加了个盖子,基本都是手机拍的图片,不是很清晰,大家对付着看吧
1: The Enterprise continues to be updated, and the living deck beams are completed. 1.5mm wooden beams are slotted and embedded in the installation. It is the first time to do the slotting. The craftsmanship cannot make a 45-degree inclined slot. The slotting depth is too large and the proportion is out of balance. 2: The progress is getting slower and slower. I can’t do much work in one day. I have completed the two bilge stairs and patched up the bilge partitions and beams. There are no whole materials. They are all made of small scraps. Anyway, they are at the bottom. , invisible. In addition, the hatch of the living deck was completed, and a cover was randomly added to the hatch. These are basically pictures taken by mobile phones. They are not very clear. Please take a look at them.
A very good looking model - a great kit is done by a very good modeler
生活甲板完成甲板压条,上了木蜡油,用铜丝做打钉,开始炮甲板的横梁制作,船头炮甲板边条位置做高了,降低船头部位的横梁位置找平,横梁先做了3个立柱,用套材内的蚀刻片做了滑轮,横梁假组,定位
今天更新一些新内容,炮甲板横梁假组后开始粘结固定,梁下立柱做了一点点造型,完成了舱室组装,门无法开启,做成了固定的,把舵的弧形梁加了铜片固定,滑轮用套材内的2个滑轮蚀刻片中间加垫片制作,目前舵杆和弧形导轨和横梁的安装位置和先后次序还要跟套材的设计者沟通确认
Some new content will be updated today. After the gun deck beams were assembled, they began to be glued and fixed. The columns under the beams were slightly shaped. The cabin assembly was completed. The door could not be opened and was fixed. Copper sheets were added to the arc beam of the rudder. Fixed, the pulley is made of two etched pulleys in the kit with a gasket in between. Currently, the installation position and sequence of the rudder stock, arc guide rail, and beam need to be communicated and confirmed with the designer of the kit.
Great work, I'm still not clear on how you create the "notch" for the crossbeam. Are you making the notch after the beams are install to the deck? if yes, how do you cut them so precisely? I'm a little puzzled! Here what I think:
a. you position a template/plan to know where to cut.
b. mark precisely on the beam
c. very unclear how you actually make the cut so that it is U-shape. any particular tools? how to avoid brake at the weak point?
伟大的工作,我仍然不清楚你如何创建“缺口”的横梁。横梁安装到甲板上后,你做缺口了吗?如果是的话,你是如何精确地切割它们的?我有点百思不得其解!以下是我的想法:
一个。你放置一个模板/计划,以知道在哪里切割。
B.B.在横梁上精确标记
C.非常不清楚如何把切口做成U形。有什么特别的工具吗如何避免在薄弱点刹车?
您好,感谢对这个1:96进取套材的关注,关于您提到的问题,我的理解是怎样在横梁上开槽安装小纵梁吧,我是固定横梁后再开槽的,这样会比较准确定位,在横梁上切出45度斜槽,再斜切出45度面,这样比垂直开全槽要简单容易,说明一下我这个槽开的太大了,跟实际比例不对,感觉像是要把横梁切断一样,会在炮甲板横梁上做改正
Hello, thank you for your attention to this 1:96 progressive kit. Regarding the question you mentioned, my understanding is how to slot the beam to install the small longitudinal beam. I slotted it after fixing the beam, so that the positioning will be more accurate. Cut a 45-degree inclined groove on the beam, and then cut a 45-degree surface obliquely. This is simpler and easier than making a full vertical groove. Let me explain that my groove is too large and is not in the right proportion. It feels like the beam is being cut off. I will make corrections on the gun deck beam.
