HMS PRINCE. Basata sui piani di costruzione Amati.
You are a very fast builder - very good progress
Only one comment to the rudder - the hinges on the rudder blade should be above the hinge on the hull - like now the rudder would fall down
Maybe you have still the possibility to adjust this
Hai ragione. Un tondino attraversa tutta la verticale del timone e passa attraverso i giunti e questo impedisce la caduta. Ottima osservazione. Grazie mille.
You are right. A rod crosses the entire vertical of the rudder and passes through the joints and this prevents it from falling. Excellent observation. A thousand thanks.
