Hms Victory by Heller
Wonderful work Peter!
And not as for the extra parts, no, just because of they way you bring them to life! Thank you for that,
Daniel
thank you Daniel, just hope can do you wonderful resin parts justice, now received your block set and your level of detail you put into your replacement parts is amazing.
More progress Hull together finnish fitting coper tape to join, did wear out rivit tool shaft but well worth it and first deck in with guns, gun detail enhanced (not all done as there not visible but did get carried away adding etch) with Daniel Fischers etch set, eyelets fitted to Hull interior for gun riging.
This is coming along great, Pete. I like the colours you have used, much better than the stark yellow and black one usually sees. Regards, Pete in RI
thank you, used Humbrol 61 flesh (near equivalent to Revell 35 Flesh Matt Acrylic 36135) (there is a difference in flesh colour if you look at interior picture upper is 63 and lower deck walls is Revell 35) and Revell 09 Anthracite Grey matt acrylic 36109
these colours were advised in one of reference books I have, hope that helps `
