Thanks, once again, for all the
likes on my previous posting!
On the Kingfisher there are posts that support the centerline of the beams of the lower deck as well as the beams of the upper deck. The posts for the
lower deck are a simple affair which would have been quite suitable for the hold:
But I wanted to make something more 'elegant' for the upper deck beams. A few years ago I had purchased a mini-lathe which I never used. Would it work to turn posts from square stock? Let's find out...
First, some blanks with layout lines:
A back-cut to prevent any tear-out:
And a preliminary beveling of the sacrificial end that would go in the chuck as well as the center turned portion:
I purchased this mini-lathe for around $30 USD:
Here we go!
Just for fun I recorded the turning of one of the posts. As you will see I just used needle files. I guess someone who knows how to properly use a lathe would use a carbide cutting tip and a pattern jig but that's above my pay grade. The video is about 10 minutes long and will show the steps I went through to make a single post. I suggest you 'fast-forward' as it's not exactly a big budget action-adventure film:
Here is a photo of the finished product:
And now the total run.
Of course, no two are exactly the same, but I believe these will work! Add another 'skill' to my model-building repertoire
