Hello Friends,
Work continues outfitting the upper deck and the forecastle deck...
First up, the simple mizzen mast partner (though cutting an octagon was harder than I thought it was going to be):
Next, the capstan step (not installed - just sitting loosely at this point because I haven't done any research on the capstan itself):
Notice the capstan step is not parallel with the deck (weird)...
Next up - the rather complicated bowsprit step (the panel with the square in it) and the topsail bitts that sit on top of bowsprit step:
In the image below you can see the fixed channels for the manger (the starboard side has panels installed - the port side will be left as is):
The manger panels on the starboard:
And now the fore deck has been temporarily installed showing the relationship of the bowsprit step and topsail bitts to this higher deck:
And finally, the cathead on the starboard side:
Installing the cathead required the unnerving obligation to cut a hole in the bulwark (and through my completed hull planking):
Considering the frightening places my imagination took me when planning this step, I'm not unhappy with this result:
But I was unhappy when I did this to the first (actually, the second) cathead
The cathead will get some sort of carved decoration on its end face - but I need to do some practicing first.
You are very kind to take some time away from your own builds to visit.
