Hello,
Sorry if i'm resurrecting old discussions about how to remove char from wood after laser cut. The only suitable answer I found here in the forum and internet is to use waterless hand cleaner and/or sandpaper. Sanding is fine to me but in the end the square plank 5 x 5mm with burnt two sides becomes 5 x 4.5 mm if not worse. I just tried using "Pumice Hand Cleaner" to remove majority of the char. In your experience, is it going to do anything to the wood overtime, color change, problem waxing, varnishing or painting?
Your thoughts and clever technics on cleaning laser burns, please...
Yuri
ps: here is the product i've used with the 6mm planks cleaned and untouched
Yuri
