How should "radar mast" be interpreted? Something of the sort appeared on the VC2 type after WWII. I haven't come across it in available blueprints. However, if you look at *Haskell*-class APA ships, radars were installed on the cargo masts. (the first 4 photos)Does anyone have a plan or image of a radar mast for a victory ship or c2.
Interesting info Roger. Hope we still have the plans. We may need them.The Liberty Ship was NOT an adaptation of the C-2 cargo ship. It ‘s evolution is more interesting.
Between World War I and World War II British shipbuilder Joseph L. Thompson developed a design for a tramp steamship. Design work progressed during the worldwide depression in the shipping industry in the hopes that it could be used when the economy improved. Known as Economy Ships, design was conservative; riveted construction, coal fired, triple expansion engines, although using superheated steam. A few vessels were built to this design prior to WWII.
Meanwhile, Americans followed a different path. The US Government’s Maritime Commission (MARAD) designed a family of state-of-the art cargo ships, resulting in the “C class”. The C-2 was one of these MARAD designed classes.
Also between the Wars, Great Britain “rationalized” it’s shipbuilding industry by closing many yards. As a result, by late 1940 Great Britain did not have unused shipyard capacity to build cargo ship tonnage to replace severe losses from German U boats.
Britain, therefore, turned to the USA to build cargo ships for its depleted Merchant Marine. A commission sent to the US found the “high end” C type cargo vessels being built in American yards to be unsuited to British needs and American shipyards full. In a remarkably short time the British Shipbuilding Commission contracted with a consortium of American companies to not only build 60 cargo ships, but the new shipyards to build them. Known as the Ocean Class these were based on the British Economy Ship Design. The Canadians also built a number to the same design known as the “Fort class ships”. The first of these American built Ocean Class vessels would be launched from the new shipyard built at Richmond, California in August 1941.
With it becoming obvious that the United States would enter the war, debate began within the US government to determine how to build cargo ships to support the war effort. MARAD officials promoted their C Class designs but a major concern was the ability of the US industrial base to mass produce the required number of geared steam turbine sets to power these ships. Finally President Roosevelt issued an executive order requiring that a design be adopted that could allow large quantities of ships to be mass produced.
The design that met these requirements was the British Ocean Class/ Economy Ship, not the MARAD C-2 Class. To better adapt it to American shipyard practices Naval Architecture firm Gibbs & Cox redrew the British plans. Major changes included, welded construction, water tube boilers, oil fuel, and a redesigned superstructure. The hull lines, (hull shape) of the liberties is the same as that of the Oceans.
MARAD designed C Class cargo ships also continued to be built throughout the war but not in the same numbers as the standardized Liberty desi
I knew the British had developed radar but their arrays were massive and land based and yes, no gun mounts so postwar. I guess you could call this model somewhere between 'static' and bare bones. Most of the structures have to be removeable for accesss to RC hardware. The modeling I've seen here for the static models is exceptional but I cannot 3d print that small of a scale.also that there are no gun mounts on the model means it is post ww2.
Skipper, radar was originally developed by the British in the mid to late 1930's. https://www.google.com/search?q=who...0j0i751l4.14090j0j15&sourceid=chrome&ie=UTF-8
Yep. Typo on the link I saw. The gymnasium at school is named after him, Ohara Hall.Sept 1942 according to these links,
I guess I didn't ask the question correctly:Richie,
Liberty ships were built utilizing all-welded prefabricated steel plates rather than the then traditional riveting. The steel was primed with
red lead primer to prevent rust and corrosion. The top coat of paint was a standard gray which closely matchedU.S. Navy Ocean Gray (FS #35164) or similar commercial-grade maritime gray paint premixes provided by commercial suppliers such PPG Industries.
Until your post I thought this was another piece of useless information in one our books at the US Merchant Marine Academy in the '60sWhat is it made of?
