Mamoli 1/93 USS Constitution Cross-Section
Not a ton of progress between yesterday and today but I did manage to keep the ball rolling. I sealed the rest of the interior of the hull and the remaining two decks with Tamiya Flat Clear Acrylic. And I got the ladders installed on both sides of the ship. I used a triangle to keep them square but the curve of the hull makes them look slightly off. Either that or I have a crappy triangle :)
No photos today but I got a few things done. I attached the platforms for the chain plates to the side of the hull and sealed the outside of the hull with Tamiya Flat Clear. I also got the decorative metal side pieces that line the companionway cleaned up - they are nice pieces but had some seam lines that I wanted to get rid of - a little filing followed by a polish took care of that.
I got my copper plates in - 150 plates. Looking at the plates next to the portion of the hull that needs to be plated makes me wonder if I have enough. I may need to order more.
I'm also toying with an idea and I wouldn't mind some feedback. Since this is a cross section model, and intended to show the construction of the ship, I'm thinking of only painting one side and leaving the other side bare wood (walnut, maple, etc.). Not on the inside of the ship, just on the outside. Thoughts?
Dominick
That plan sounds good, painted and copper finish on one side and beautiful wood on the other.
Kurt,
Thanks. Yes, it was a good plan. However, the best laid plans of mice and men...Some white paint got under the masking when I was airbrushing the interior so I was forced to paint both sides. Oh well. It still looks great.
Dominick
It may not seem like a lot but I painted the cross-section this weekend. In keeping with my original plan I left the interior of the hold, including the bottom of the lower deck as bare wood sealed with clear. I painted the interior from the lowest deck up to the bulwarks white, including the underside of the middle and top decks. I painted the bulwarks Vallejo Flat Green which looks like a good match for bulwarks green.
My plan for the exterior was to paint and copper plate one side of the hull and leave the other side bare wood to show off my handiwork. However, when I airbrushed the inside of the hull white (Tamiya Flat White - XF2) thinned 50% with Tamiya thinner some of the paint got under the tape I used to cover the outside cannon ports and I was forced to paint the whole exterior. I hand painted Vallejo Black so I wouldn't have the same problem. Anyway, it still looks good.
The decks are just slid in for now. I won't install them permanently until after they are detailed. Then I'll work from the bottom up. The only thing I'll need to do between the decks after installation is install brackets to the sides and install the columns.
Next up I'll give her a coat of Testors Dull Coat, add the copper plates, patina the plates, and mount it to the display base which I may make from a piece of live edge maple I have laying around.
Dominick
I just joined this forum and noted in my intro that my wife presented me with this kit in 1985. After numerous moves, the project has probably sat idle for ~ 30 years. Now I have a place to spread out and work on it. Currently, I am reviewing my inventory and getting familiar with the plans... again. This is my first wooden ship model so the rigging details are a bit unfamiliar and looking at the rigging plans on Table 3 and Table 4 is a bit confusing / overwhelming. I did note that the plans call out for painting the rigging black as all of the threads are beige. I'll be purchasing the black rigging threads instead. Hope you don't mind me asking questions and chiming in on your build log. Excellent work!
...henry
I understand. I just finished Model Shipways "Fair American", forums and it not a fun build, because of the very poor directions. I would not have finished it without help from internet forums. Thanks
I've had this kit in my stash for quite a few years and I think it's finally time to build it. I know that the kit is chock full of inaccuracies, it's missing a deck Mamoli modeled 3 decks instead of the correct 4), there is a cannon on the main deck (probably added to create display interest), the pumps are the wrong type (looks like they used the style they were changed to in the mid-1800s), there's no plumbing below the pumps, a brace is missing from the hold bottom, and probably a host more.
However, I don't care, I'm not building it for a museum piece but to hone some of my skills and as a nice display piece for my office. I really like that it models the full main mast rather than just a stub mask that some of the larger scale models use. The only changes I'm planning to make are, 1) scribing joint lines on the outside frames to add both realism and visual interest, and 2) maybe carving and adding the brace in the hold.
I plan to follow the build instructions with a few exceptions to make it easier to model. I'll build the frames flat (add spacers to each frame individually) and then stack them. I also intend to build and populate each deck separately, then slide them in like drawers and add the final details. That will make it much easier to add all of the details to each deck and do final assembly from the bottom up so I don't have to try to place items between decks with a tweezer. After all, it's 1/93 scale so pretty small.
And away we go....
Dominick
Hallo Dominick alias @DSoldano
Did you finish your section model in the meantime?
Your work is neat as a pin. I have this kit as well and ruined it as I thought the pieces we accurately cut, you obviously found the flaws early and corrected them. I look forward to your next post as your work will turn this into a beautiful piece.
And away we go....
Dominick
