- Apr 3, 2023
I'll also nominate FrogTape... you can get it in a variety of widths, and it's grippy enough I can use it for multiple purposes (I use it a lot for hull planking when I'm doing a thin second veneer layer in walnut, as an example). Plus it readily peels off without leaving residue on the wood. Its my "go to" material for many things, especially when typical clamps aren't going to work. But if you're looking for a line masking material, I'd lean towards plastic model painting tape as its better suited for those razor sharp edge lines. Another forum member noted the Tamiya products and I use those for painting purposes. Frog Tape is my clamping tape.I am happily using the 'FrogTape', it is prevented from paint bleeding.
FrogTape Painter's Tape
The only painter’s tape with Paintblock Technology®, FrogTape® is the painter’s tape for every job, whether you’re a home DIY or professional painter.www.frogtape.com
