I have used the automotive striping tape for many years for the waterline on my RC ships. It can be purchased in various colours, and I usually use it in 1/16 (2mm) or 1/8 (4mm) widths. I have never had it come off even when cleaning the model after it comes out of the water. I also use "Scotch" Plastic Tape for masking around windows or doors before painting. It seals perfectly with no bleed and comes off with no gooey residue.I believe there is a striping tape you can buy probably at a local hobby or hardware store. I was inquiring about the best way to paint small windows on my lake freighter on a Facebook group and striping tape was recommended - never did go looking for it yet though.
In reference to "clear if no paint", what would you recommend? to seal the edge? I'm working on a Soleil Royale and getting close to the painting. It's a blue over the light colored wood, almost a basswood. The last thing I want is bleed through, thank you.Please realize that all masking tape can bleed under the edge, regardless of brand and type. Key for success is to first spray the same color as the base (or clear if no paint)...that seals the edge. Once that is dry only then do you spray the color you want lined off....nothing will bleed and you will be the envy of your modeling friends!
When painting a masked edge against unpainted wood, I would first spray on a clear coat of whatever paint system you are using. I often use a paint brand called "Scalecoat" but there are many others. For those wanting to use water base paints I have had success with Vallejo.In reference to "clear if no paint", what would you recommend? to seal the edge? I'm working on a Soleil Royale and getting close to the painting. It's a blue over the light colored wood, almost a basswood. The last thing I want is bleed through, thank you.
thank you for the response. I was thinking of masking then brush on a thin line of some type of clear to get that seal. I've been thinking about this for a while now and your idea seems like the best idea yet. I've had problems in the past with seepage below the masking. Will try on a sample first before the model.When painting a masked edge against unpainted wood, I would first spray on a clear coat of whatever paint system you are using. I often use a paint brand called "Scalecoat" but there are many others. For those wanting to use water base paints I have had success with Vallejo.
Most brands will have a clear available in their lineup (often in either matt or gloss finish)...After masking the line, first spray the clear, then once that is dry spray the color coat.
Hope this helps.
Yes, this is true. I also like this masking tape brand.Try the yellow Frog Tape. It works just like the Tamiya kabuki tape at a fraction of the price.
