The specifications for rigging Merchant Ships and Brigs are folded pages. The specs for schooners is laid out. Am I reading this wrong? Where is the additional information? Example: see pg 164.It's really not rocket science. There's an established sequence for rigging full-sized vessels with crossed yards and that schedule works as well on a model as on a full-scale ship. The one exception is that modeler will propbably want to attach to the top hamper blocks with appropriate lengths of running rigging rove through them, and similar small details, "off the ship" and prior to "sending them up" because doing so, (particularly the reeving of blocks,) will be more easily accomplished on the bench.
The sequence of rigging a sailing vessel is set forth in detail for the various rigs in two primary treatises, the first being The Art of Rigging by David Steele published in 1794, often referred to simply as "Steele's" and the second being a new and revised edition of The Art of Rigging published by George Biddlecombe in 1848 and often referred to simply as "Biddlecombe." Each address what the authors describe as "The Method of Progressive Rigging." These works indicate work which can be performed "ashore" prior to installation on the vessel. This "ashore" work should be done by the modeler "on the bench, together with such other work as may be more convenient to do off the model itself. In any case, the order of installation of elements on the model should parallel the installation of the same on the full-scale ship.
Below are links to each of these seminal works. The two Art of Rigging PDF's are listed in the "Masts and Rigging" section of the Model Ship World forum's "Articles Database" at the top of their homepage. If you cannot access them from the below links then try https://thenrg.org/resource/articles, or you may have to sign in to that forum in order to gain access to them.
