For a bit of fun, I asked ChatGPT to figure out what it may be.
I have very little confidence in this tool set as it often comes up with absurd responses when I post challenging questions to it.
The only thing I use it for is checking my grammar on important documents.
So let the fun begin:
I am going to load a picture. This item was found in a sunken 1784 British Warship by some archeologists. They are trying to identify what it is. Could you please give me your top 5 opinions? Note that there are some makings on the item.
Stopped thinking
This is a very intriguing artifact. Based on the shape, material, cutouts, and the apparent engraved marking (“MELA” or possibly “M:ELA”), here are my top five possibilities for what it may be from a 1784 British warship context:
Why this fits:
Possibilities include:
If you would like, I can also:
Ok thanks, one person thought is was an hour glass holder similar to this. What are your thoughts?
Yes — after seeing this comparison image, I think the “hourglass holder” theory becomes substantially stronger, possibly even the leading interpretation.
The similarities are actually quite striking.
Here’s why:
The cutouts would:
However:
If you'd like, I can also:
Stopped thinking
1. Decorative Brass Sleeve or Ferrule (Most Likely)
This may be a brass ferrule — a reinforcing or decorative sleeve fitted around:- a telescope,
- spyglass,
- knife handle,
- powder tool,
- officer’s baton,
- or a naval instrument.
- an owner’s initials,
- a maker’s abbreviation,
- or part of a longer word/name now lost.
- Brass was common aboard Royal Navy vessels.
- Officers often owned decorated personal equipment.
- The object appears rolled from thin sheet brass.
2. Part of a Naval Lanthorn (Lantern) Vent or Guard
The cutout pattern resembles ventilation openings seen in:- candle lanterns,
- powder-safe lamps,
- or protective guards around flame sources.
- airflow,
- light diffusion,
- or heat escape.
- Ships carried many brass lantern fittings.
- The folded sheet construction is consistent with lighting hardware.
- The warship environment required specialized flame-control devices.
3. Decorative Mount from a Sword, Dirk, or Firearm Accessory
It could be part of:- a scabbard throat,
- pistol accessory,
- cartridge tool,
- or sword belt fitting.
- leather,
- velvet,
- wood,
- or another inner material.
- Officers’ weapons frequently had pierced brass ornamentation.
- The dimensions seem compatible with hand-held equipment.
4. Musical Instrument Component (Bosun or Fife-Related)
The shape and rolled construction somewhat resemble fittings from:- a fife,
- pipe case,
- bosun’s whistle accessory,
- or instrument holder.
- resonance,
- grip,
- or decorative presentation.
- Naval vessels carried fifers and signaling instruments.
- Personal engraved items were common.
5. Early Naval Optical Device Component
This could potentially be from:- a spyglass,
- viewing tube,
- navigation aid,
- or protective cover for optics.
Why this fits:
- Brass optical fittings were extremely common in the 18th century.
- The rolled cylindrical form strongly suggests it once fit over another object.
Additional Observations
Material
The artifact appears to be:- brass,
- bronze,
- or heavily patinated copper alloy.
The Marking: “MELA”
The inscription is extremely important.Possibilities include:
- a maker’s mark,
- abbreviated surname,
- ownership initials,
- or partial Latin/Italian/French wording.
- a craftsman,
- a naval supplier,
- or even a shortened name such as Melas, Meller, or Mela.
- a sharper macro image,
- raking light photography,
- or X-ray fluorescence scans,
it may reveal whether additional letters are missing.
My Overall Best Guess
My strongest instinct is that this is:The craftsmanship and symmetrical piercing feel more decorative than purely industrial.a decorative brass sleeve/ferrule from a personal naval instrument or officer’s accessory.
- compare it to known 18th-century Royal Navy artifacts,
- analyze the engraving style,
- estimate the original full shape,
- or produce a reconstruction sketch of what the complete object may have looked like.
Here’s why:
Strong Points Supporting the Hourglass Holder Theory
1. The Shape Matches Extremely Well
Your artifact has:- a rolled cylindrical body,
- large opposing cutouts,
- narrowing toward the center,
- and reinforced ends.
The cutouts would:
- allow visibility of the sand,
- reduce weight,
- and protect the glass bulbs from impact.
2. Naval Use of Sand Glasses Was Extensive
A 1734 British warship would have carried many sandglasses for:- timing watches,
- navigation,
- dead reckoning,
- speed measurement,
- and gun drill timing.
- 30-second glasses,
- half-minute log glasses,
- 28-second glasses,
- and half-hour watch glasses.
3. Brass Was Ideal for Marine Conditions
Brass resisted:- salt corrosion,
- humidity,
- and wear.
- brass,
- bronze,
- and copper alloys.
4. The Size Seems Appropriate
Your object appears roughly consistent with:- a handheld or mounted sandglass frame.
5. The Engraving May Indicate Ownership or Maker
The “MELA” marking could fit:- a maker’s signature,
- owner’s initials,
- or an abbreviated surname.
One Important Difference
The major question is:Where are the end fittings or retention features?
Most hourglass holders:- either screw apart,
- have retaining rings,
- or include internal shoulders holding the glass in place.
However:
- corrosion,
- crushing from sinking,
- or missing attached components
could explain this.
My Revised Ranking
After seeing your comparison image:- Hourglass / sandglass protective holder ← now my leading theory
- Decorative sleeve for navigational instrument
- Lantern or lighting component
- Weapon/accessory mount
- Optical instrument component
Additional Historical Clue
British naval sandglasses from the early 1700s are actually somewhat underrepresented archaeologically because:- the glass rarely survives intact,
- brass fittings were often salvaged,
- and wooden mounts decayed.
My Overall Assessment
I would now estimate there is a fairly good probability this object was associated with:The opposing windows and cylindrical sleeve construction align very naturally with that function.a marine sandglass (hourglass) used aboard the ship.
- compare this against known Royal Navy sandglass artifacts,
- estimate the original dimensions of the glass,
- identify what type of shipboard timing glass it may have been,
- or create a reconstruction drawing showing how your artifact may originally have looked complete.
