That lathe you got looks to small for masts and spars. My 18” one was barely big enough. I found it a lot easier to taper yards with it than to use a drill and sand paper. Once you get used to using the lathe, you can do some pretty fine stuff with it. You do have to leave some space at either end. I only turn the part nearest the chuck. The other end can get wobbly because it’s not as well supported, so I generally turn it around to do the other end.
