You solder then BEFORE you insert them into the slots of the channels. Don't burn the wood. And don't forget to link the chainplates before you close the gaps with solder, unless you also have seams on the chainplates to solder.
Soldering is a skill that I will have to learn very soon as outside of canoes it seems to be needed frequently. PT-2@PT-2 I dont think soldering would really bother the wood any, especially if you use some clamps or forceps to absorb the heat just past the join you are making. I just wish the kits manufacturer would have been more clear on their intentions for the strops to begin with, then our OP wouldn't be guessing what to do. I dont mind people asking questions at all, but kit manufacturers seem to expect everyone to know what they were thinking designing a kit. What the hobby needs is more clarity in the steps of construction for those who dont know everything( no target in mind, just a general observation )
learn very soon
Thanks for your tutorial for a needy student. Homework time! PT-2Biggest thing, dont rush it. Make sure the parts are clean. Apply a little flux where you want solder to bind then apply heat with your iron.
hold the solder to the join and when the part reaches the right temp the solder will wick in where the flux is. Remove the iron and let the part
cool a minute. It takes practice but after a few test pieces you'll have the idea and get pretty good.
Excellent example of working around a problem in the best of flow like water around a rock. PT-2Well...a perfect time for some kit bashing. I would abandon these strops and make my own with black wire if suitable gauge. Wrap around the deadeye, twist closed below it Including a lower loop, place in slot on channel and lock in place with a drop of CA. There are other methods of course. My point is if one method is troubling as is the case here go ahead and do something different!
