What’s a good wood primer to use on kit supplied wood? Is there a good/better/best paint manufacturer?
Are you thinking of keeping a naturalwood appearance, or painting over the primer with a color? There are several acrylic primers. I like the acrylic primer I boght from Model Expo. Other fnishes that perform well as a primer is de-waxed shellac and brushing lacquer. I have also used Watco Danish Oil first allowed to fully cure, then followed by lacquer or even spar urethane. Its best to try your selection on scrap first to see what you think....What’s a good wood primer to use on kit supplied wood? Is there a good/better/best paint manufacturer?
Some woods are very porous and will drink the paint. Some primers stop this.I just paint wood directly with acrylic paints. Am I wrong? What the reason to prime the wood?
Good primer for wood , Zinsler "Bullseye" --- airbrush acrylic over Bullseye - then clear coat to hole color used , won't fade over the years ... Take your time ....What’s a good wood primer to use on kit supplied wood? Is there a good/better/best paint manufacturer?
Shellac can be pretty bullet proof.....EXCEPT! Alcohol! Alcohol will melt, thin, mar, destroy shellac. Use care....I haven't used Liquitex. Is it acrylic?I’ve used shellac but currently use Liquitex matte varnish as primer, then Vallejo Model Color acrylics. I always brush and get results equal to spraying (or better). Less prep, easy cleanup, vast array of authentic looking colors too.
Hey Phil, yes Liquitex is water based low-odour acrylic. I use it as a finish, it's the best matte I've found, all others I've used have been nearer satin than matte.Shellac can be pretty bullet proof.....EXCEPT! Alcohol! Alcohol will melt, thin, mar, destroy shellac. Use care....I haven't used Liquitex. Is it acrylic?
Yes, it’s acrylic. I’ve used it by itself to finish cherry baseboards. Six coats —flattened after each coat with fine bronze wool until the grain is filled up. Then flattened one more time and applied furniture paste wax and buffed. A beautiful wax finish. I might use shellac again (amber or garnet) to darken a pale wood baseboard.Shellac can be pretty bullet proof.....EXCEPT! Alcohol! Alcohol will melt, thin, mar, destroy shellac. Use care....I haven't used Liquitex. Is it acrylic?
