Reale De France - Corel - 1:60
Thanks. I try, but I'm still not very happy with myself. Working on myself :)
Здравствуйте Игорь. Можно работать над собой и моделью тоже. Так сказать в тандеме. Мы с нетерпением ждем ваших отчетов по постройке. Удачи в самосовершенстве. ;)
Hello Igor. You can work on yourself and the model at the same time. So to speak in tandem. We look forward to the new developments in your model. Good luck in self-perfection.
Thanks!
Small report. Finished work with the body, there is something to finish - not critical. I'm moving on to the next stage. I was surprised that there is only one mast in the bow, and there are two places to install it, I will think. I will suffer with flags, but I think I will solve everything. Good luck to all do not get sick!!
Небольшой отчет. Закончены работы с корпусом, есть что доделать - не критично. Приступаю к следующему этапу. Удивило , что в носу только одна мачта, а места для установки два, буду думать. С флагами помучаюсь, но думаю все решу. Удачи всем не болейте!!
When it's finished. Just in time for the day the Navy did, despite all the sad personal events. I wasn't happy with everything. If questions to the manufacturer of the set and to your hands, especially your eyes. But the result is pleasing. If you have any questions please ask
Законченный вариант. Не всем остался доволен. Если вопросы к производителю набора. Но результат радует глаз. Если есть вопросы задавайте_090936.jpg14.jpgкоп00726_090920.jpg21.jpg20200728_185709.jpg20200728_185643.jpg_090936.jpg14.jpgкоп00726_090920.jpg21.jpg20200728_185709.jpg20200728_185643.jpg
Well that is a fantastic model
Hard to give a proper appreciationFirst Place MetalThumbs-Up
Question for you did you do something special to avoid the pennant to Frey and you use the sail supply in the kitQuestion-Mark
[/QUOTE]
Good afternoon. Explain Your question on pennants, for reading I use an Internet translator.
I used the pennants included in the kit. I soaked them in a solution of PVA glue, then cut them out. Cords with tails made separately (there is a photo, see above)
