Revell B17-G Modified to a B17-H 1:48
Houston,Texas
Good after noon everyone. I'm back in this corner of SOS again this time presenting my build of a WWII B17-G bomber. My plan is to modify this kit to carry a 40' Higgins lifeboat hung underneath on the belly of this bird. Of the 12,371 B17's built only 130 were actually converted to lifeboat carriers where they would follow air sea battles in the pacific theatre and drop these boats via parachutes over downed US or allied planes. My father was a pilot in the 13th Army Air Corps of one of these planes which he and his crew flew out of a detach squadron located on Palawan Island in the Philippines. So, this build is a tribute to my dad and his service to our country as an Air/Sea rescue pilot. His time spent over there from late 1944 to 1945 when the war ended. I'll start by unpacking and show a spread of still in plastic bags parts. It has a 24" wingspan and 18" fuselage so its decent size at 1:48.
I found a few pictures of this plane on the web, as it may seem quite odd to some who have not heard of this modification. These pics are undoubtedly from the late 40's or early 50's. They stopped using B17's for this in the 50's.
This next photo is kind of small, but you can see it in action.
I found this photo of my dad in our family archives; he is standing on the nacelle third from the left.
In addition to modifying the paint scheme I also have to scratch up modified model A-1 Higgins boat. I hit the jackpot with a fella named Patrick who has a company called Warbird-Manuels, not cheap but very necessary. He had a copy of the Higgins A-1 repair manual which has all the data I needed to design on my CAD program a scaled bulkhead style boat. Check it out.
My 1:1 cut outs 9 bulkheads a transom and a keel to attach everything to.IMG_0592.jpgIMG_0593.jpgIMG_0594.jpg
I will plank it with some obeeche then paint it bright yellow. I have to figure out a way to attach it to the plans belly.
I spent a hour or so brushing up on my airbrushing skills, hope I can pull this aspect of painting off. Anyway, here are the main parts dry fitted after spending a while on clean-up of the plastic nibs and such, still have a long way to go before I start painting.
So, everyone welcome aboard, this time you don't have to lay on the wing like my Wright Flyer you can pull up a chair.
Interesting subject. I'll take my seat in the Higgins.
Welcome aboard Ron.
Count on me as well! Great story and should be an interesting build.
Great to have you Jim.
Very cool project. In the headquarters where I work there is a painting of a similarly modified B-29 about to rescue a downed pilot.
Welcome aboard, yep B-29's, were also converted. PBY Catalinas (the flying boat) were in service as well.
very Cool backstory. I'm in too :)
Hey Shota, glad you made it.
Flying boats, the golden age of aviation. ROTF
Welcome aboard Smithy. (The following information is from Wikipedia) The Higgins A-1 lifeboat was to be dropped by an SB-17 traveling at an airspeed of 120 miles per hour (190 km/h) and an altitude of about 1,500 feet (500 m). Precisely as the aircraft passed directly over the rescue target the boat was to be released. The boat dropped free for a short distance, then static lines attached to the aircraft's bomb bay catwalk drew taut, pulling out three 48-foot (15 m) parachutes of a standard U.S. Army design. Under the open parachutes, the boat took on a 50° bow-downward angle and descended at a rate of 27 feet per second (8 m/s), or about 18 miles per hour (29 km/h). In a manner similar to Fox's airborne lifeboat, upon contact with seawater, rocket-projected lines were automatically sent out 200 yards (180 m) to each side to make it easier for survivors to reach the Higgins lifeboat. The parachutes settled into the water to create a sea anchor holding the boat steady while survivors worked to reach it. Inside the boat, the crew of the aircraft that dropped the lifeboat would have placed a map giving the approximate position of the boat and a recommended compass setting to take in order to facilitate rescue. The yellow-painted vessel was supplied with enough food, water and clothing for 12 survivors to last for about 20 days in the ocean. It was provided with sails kept relatively small so that inexpert operators could use them. A "Gibson Girl" survival radio was aboard with an antenna to be lifted up with a kite. Its two engines propelled the boat at 8 miles per hour (13 km/h); if just one were used the speed was 5 miles per hour (8 km/h). The effective cruising range was about 1,500 miles (2,400 km) with some 100 to 150 miles (160 to 240 km) made per day.
A fun little update here regarding the A-1 Higgins boat. After printing the scaled keel, I trimmed it out of the paper and glued it to the 5mm basswood piece I had then jig sawed it out a little oversized then drum sanded it to the profile on the paper. I would have worked on the bulkheads but need to get to the hobby store tomorrow for some thinner 2 to 3mm basswood.
Till next time!
I have that kit sitting on my shelf. Good to see you can use your ship building skills along with plastic skills.
I have seen movies from WWII era where these rescue planes were used and dropped boats to survivors so they got food, water and shelter while waiting for rescue pickup.
Hang on tight to your seat for when it gets dropped the 2-300 feet they flew at when releasing them.
Hi Kurt, statistics claim the boat was dropped from 1500 ft. going 120 mph. It needed the altitude to have time for the parachutes come out and open up to slow it down. Otherwise, it would hit the water like a torpedo and sink. I remember my dad saying the plane would suddenly lurch upwards when the boat was released though.
