Russian "Four-oared Yawl" | Scale 1:24 | Falkonet
algunos avances:)
Reemplacé todos los "clavos" láser con varillas de latón ennegrecido.
La madera está aceitada y luego usé "Ballenmattierung" para darle un poco de brillo. Con este tratamiento me gusta mucho el color de la madera del kit.
salud
Puñal
Las cuadernas de los kits son, casi siempre, mamaros, que como luego se forran no se ven. Pero luego de forrar las tu las has vaciado dejando solo las cuadernas para trabajar el interior ¿Cómo lo has hecho? No parece fácil. Me gusta mucho tu barca.. felicitciones
To build complex things like the Polotsk is not possible at the moment, there is just not enough time. But I needed something between my fingers, a small project which is feasible while our little daughter is still ... very small.
Generally I like small boats very much and therefore I decided for a Russian "Four-oared Yawl" in scale 1:24 from Falkonet.
In itself a nice kit with a but unfortunately partly widespread problem. It is lasered idealized, i.e. it is not taken into account that 2 x 0.05 mm laser burn marks are removed from each plank, I like to do this very thoroughly, which then unfortunately accumulates to over 1.0 mm. Annoying if you then have to widen one or more planks. But I think the fewest will notice. At the stern, I can say right away I should have let the widening be, but even that I get probably "workarounded" :-D
The frames I have made from 1.0 x 1.0 mm sawn pear strips, I did not wanted to clean and glue the provided 2 x 0.5 mm lasered strips :)
History reference
In the 19th century, the English shipbuilder Veniamin Fomich Stoke built more than 600 ships of various ranks in the service of the Russian Empire, including the famous frigate Pallada. The archives contain many drawings of boats of his authorship, among which the yawls deserve special attention, as the most massive and simple of all types of small vessels. Usually they had clinker sheathing, one mast and 2 to 8 oars. Most of the ships of that time were armed with yalami in order to perform tasks of a different spectrum: reconnaissance, supply and transportation of the crew. They found no less widespread use as a pleasure craft or port boat.
Our yawl was reconstructed according to an archival drawing from the funds of the RGAVMF, its forms are closest to modern models, but at the same time, it has a characteristic feature - these are teardrop-shaped contours that add beauty to its outlines. This prefabricated model is an excellent tutorial for beginner modellers on the device and the general appearance of the boat.
cheers
Dirk
Hallo Dirk alias @Dubz Modelling World
Enjoy your special day
Thank you very much for the birthday wishes :)
And we continue with the "interior" :-)
Btw, the very nice supports turned from pear are part of the kit :-)
The brass parts were blackened with the brass stain from Dräger. Use a sanding pad to make the brass bright, then 10 seconds in the stain and you're done :-)
Again, a little improvisation was necessary because of the precision of the laser work, which does not always work in reality. The seats could have been 2 mm wider :-D
The mast securing looks good and works by the way, even if I think the belaying pins could have been a bit bigger.
Here, all the etched nail holes have been drilled out and replaced with miniature rivets. I like this, if slightly "exaggerated", impression.
cheers
Dirk
Muchas gracias por los deseos de cumpleaños.:)
Y seguimos con el "interior":)
Por cierto, los soportes muy bonitos hechos de pera son parte del kit.:)
Las piezas de latón se ennegrecieron con el tinte de latón de Dräger. Use una almohadilla de lijado para hacer que el latón brille, luego 10 segundos en la mancha y listo.:)
Una vez más, fue necesario un poco de improvisación debido a la precisión del trabajo con láser, que no siempre funciona en la realidad. Los asientos podrían haber sido 2 mm más anchos :-D
Por cierto, la fijación del mástil se ve bien y funciona, aunque creo que los pasadores de seguridad podrían haber sido un poco más grandes.
Aquí, todos los orificios de los clavos grabados se han perforado y reemplazado con remaches en miniatura. Me gusta esta impresión, aunque un poco "exagerada".
salud
Puñal
Muy buena construccion. Lástima que sea un kit.....
