As already discussed before, there are advantages and also disadvantages of the scroll and also the band saw.
Usually with a band saw, there are not so fine curves possible, like with a scroll saw.
But it seems, that Pegas has an alternative band saw, which full fills this needs
Pégas Scroll Band Saw
Pégas Scroll Band Saw | Sawing | Dictum
www.dictum.com
The precision band saw from Pégas is a global innovation which works with the finest and most precise saw blades that have ever been made. This unique development is dedicated to both hobbyists and professional users in the woodworking industry.
The heart of the machine is a specially developed roller guide system that is perfectly adapted to the Pégas fine-cutting saw blades. The guide consists of one roll bearing above and one roll bearing below the machine table that contains a guiding groove which is adapted to the respective fine-cutting saw blade.
The extremely slender fine-cut saw blade with a width of only 1.02 to 3 mm is guided perfectly without any twisting, enabling even the finest cuts with complicated shapes and the narrowest radius of less than 2 mm. The special tooth design avoids vibrations completely and provides for a high cutting performance with an incredible smooth finish of the edges. For soft and hardwood with a thickness of up to 150 mm.
Additional advantages:
- Machine table working height 106.5 cm (optionally adjusted to 78.5 cm for seated working position - Replacement feet No. 716063)
- Machine frame and table made of warp-resistant cast iron, lower frame and roller coverings made of sheet steel
- Machine table can be tilted up to 40°
- Two speed levels
- Safety switch in both doors prevents the machine from being turned on with the door open
- Balanced track rollers made of aluminium covered with replaceable rubber bands
- Diameter 65/58 mm connecting pieces for optimum dust extraction
- High dead weight, approx. 70 kg, for vibration-free operation
It is a very high price, but it is maybe worth a second look - Does somebody has already experience with this kind of saw?
