SPANISH GALLEON XVII
ramonolivenza
Well-Known Member
Madrid, España
#61
Yes, but that's a Dutch galleon. These galleons were built differently from the Spaniards and the English, they were built with the skin first technique. First the outer plank was constructed and then the frames were added. In the Spanish it is the opposite
JosephH
Well-Known Member
Blandford Group Build
#62
but they did it 2 ways the first way i posted is similar to the way you did it. the second way shows the other method the plank first.
Uwek
Well-Known Member
Vienna, Austria
#64
These clamps are really helpful for such kind of work - I will order also some of them!!!
Your work on the frames looks very good - very interesting to see this way of sequence :cool:
Uwek
Well-Known Member
Vienna, Austria
#67
It is looking so fragile without the use of an outer jig to fix the frames during the construction of the hull.
Especially when we see, that you have now on one side two of these brass clamps which produce some torsion on the keel.
You have to make it very careful and check very often, I guess?
Very interesting building log my friend
ramonolivenza
Well-Known Member
Madrid, España
#68
Not so frágiles... ;)
ziled68
Well-Known Member
#72
Hello Ramon,
Your galleon is looking spectacular. While it scares me to see you hold it like that, I imagine that you are confident as to its strength. If it was me I would hold it in two hands while making sure that there are a bunch of pillows on the ground. By the way, I could not help but smile at your red and white striped shirt. It reminded me of the picture game I would have my children work on,
"Where's Waldo". Thanks for bringing a smile to my face.
Raymond
ramonolivenza
Well-Known Member
Madrid, España
#73
Hello Ramon,
Raymond
hahahaha ..do not be afraid the construction is very solid .. I'm glad you like my "domestic elegance",
ziled68
Well-Known Member
#77
Hello Ramon,
I am now understanding the concept you are using for your build (at least I think I do). When you started you had the front, middle and rear frames completed followed by the getting the general shape of your galleon via the batons. I am now seeing that you are filling the remainder of the frames working aft using the batons as a guide to get the correct shape of your galleon. That is quite the nifty little trick (then again I might be wrong but it sure seems that way to me). Was that your thought process when you first started out? If it was, Bravo to you Sir.
Raymond
JosephH
Well-Known Member
#78
Yea Ramond the dutch did it that way also in one of their methods I think pre 1700 they did the plank the hull then add the frames and after 1700 they did it the way Ramone and the spanish did it.
rek
New Member
#80
Could you provide the source where I could obtain a set of plans you are using for your build
