Swift 1805 - Artesania Latina 1/50
  • Thread starter Thread starter buffie
  • Watchers Watchers 1
Hi I have started with my first model this year round February, and would love to get some feedback on my progress.
I started with the Swift 1805 - (Artesania Latina) and I have now reached the stage where I had to expand on my limited set of tools! So far I have used only my hands, glu and one or two different wood cutters. I am proud to say I have just bought a Dremel 200 series to complete my model in style. :D
Can someone point me in the right direction to add some pictures?
Thanks
Thank you Popeye for responding to this, I would like to add:
Hi Buffie,
I went to the "SOS build log for kits" and I don't remember seeing a Build Log started by you. You might have, but I did not see it right off the bat.
If you have not done so, then navigate to this page http://shipsofscale.com/sosforums/viewforum.php?f=52
This is the root of the Build Logs for Kits. Then at the near top of page is a button "New Post" and in the Subject line you will write something like:
Swift 1805 - Artesania Latina 1/50. Then in the body area where you start your post just like replies, write up your comments as this Board requires at least one (1) character before the post will be active.
Then near the bottom of the comment box (you have to use the mouse to scroll down just a little) and you will see "Options" and "Attachments".
Click on Attachments and you will see a white button that says "add files". When you click that, your local computer file browser will allow you to choose the file and then when you do, it will make provisions for the attached file. Then you will notice to the right there is a small comment box if you want to use that. Then you can "preview" your post and if you are happy with it, then click submit. The rest is done. Once the photo is attached, it is attached. Of course you can delete it if you wish. It is not like the old forum that you have to perform one more step. The "INLINE" option is if you want to put your image INLINE with your text. I suggest that you go to "Test your Post here" forum to try things out first.
I hope this helps.
Donnie
I have to apologize, I am very new to Forums and I did not know I had to create a build log... so I have done what you asked Donnie, can you please check if I followed the right steps.
Thanks
Buffie,
Your new post for the new build log is Perfect !!! I already made a reply to it. Nice project, I am glad that you are participating.
Donnie
