I painted and glued the two side parts for the Hapunen platform.
Before I dropped a part and I didn't see where it fell. After a good 10 minutes and even more gray hair, I found the thing in the trash can again. I was already despairing.
Then I picked out the parts for the front mast.
Hello
Unfortunately for me things are progressing very slowly.
I don't have the time and there are a lot of little things to tinker with.
That's just part of it, I often don't go fast enough.
I'm just an impatient guy sometimes.
We continued with the mast.
It took a lot of time to get everything together and work my way through the construction plans.
But now I have everything and have made the parts to size.
The lookout buoy......I have to see what I'm doing there, the thing was stowed at some point. Ok, we'll see.
I shortened the crow's nest a little, otherwise the ring with the railing would no longer have fit over it.
It looked like this before and after processing with a large hole for the crow's nest, a small hole where it is placed over the mast and 3 0.8 mm holes for the railing.
Then I prepared the soldering device for the railing, so the glue has to dry first.
I started today with 2 roller stands. First I looked for the small parts together and after an intensive search for 2 rollers, I discovered that they were missing from the fittings set
OK, there's nothing you can do about that. After thinking about it for a moment, I thought there had to be a replacement.
Traced on 3mm plywood with a compass, roughly cut it out, then drilled a hole in the middle, put a screw through and secured with the mom.
Then I clamped the screw on the drill and ground it to size at full throttle.
Now I have to think about how I can get the rope guide into the roll, do you have any ideas?
I like that better. I removed the screw again and the first coat of paint is on it too. And this is how I will continue!
I'll first put all the structures together and paint them, then I'll attach everything and then the railing will come on.
That's my plan (without guarantee)
