- Oct 1, 2023
Oh my. I removed all of the beams and reinstalled them behind the frames. As mentioned earlier I fudged a couple to make the openings work with the openings in the finished deck. The last few days I have been looking at how the finish deck is going to fit at the stern (putting the beams behind the frames) and wondering what is wrong.I just read the post from Daniel and got triggered on his quote:
That's contrary to what I wrote:
I can't refer to my own build because I made a completely different setup of the deck beams.
So, I made a closer look to the manual and drawings. There is reason for some confusion.
Why do they point rib/frame 1 and beam 126-1 close to each other, draw rib/frame 2 and pointed then the number '2' behind that second frame ???
The beam is drawn 'clamped' between rib/frame 1 and 2, but the beams are not that wide.
In the Manual they wrote (translated): " .....Note the back close to the ribs ......"
I suppose they mean "..... Note the back (of the beams) close to the ribs ........"
Then beam 1 must be in front and against to rib/frame 2 etc.
Why do you draw with (Chinese) text special attention to rib 1 on that drawing?
That's why I interpreted it as "the beams behind of the frames".
I made a closer look to the picture 85 on page 15. The picture has a low resolution. So I pimped it a bit up.
Then you can see that the lay the beams in front and against the ribs/frames. It's hard to see because they made the picture with a wide angle:
The black arrows are pointing to where you can see the beams in front of the ribs/frames and the gaps in front of the beams.
On the next page of the manual there are some better pictures, but still in a low resolution:
So, Ted: Sorry for my misinformation and Daniel is right!
Perhaps you can get now a better alignment for the vertical beams in the front.
I'm a little confused now. Does the back of the deck beams fit up against the forward side of the frame or just near it
Thank all of you for your assistance.
Ted
