I cannot believe it is over three years since I worked on my Royal Caroline, so for a change I have dusted her off and will continue with the build, but first there are some repairs to make, one side of the main cabin was damaged and the two front windows had the top parts of the frame broken off, so i decided to repair these first,
I damaged the top edge of the cabin roof when I accidentley bumped it into the side wall,
I cut the whole side plank off and replaced it, you can also see the broken frame in the first window,
after replacing the plank,
To repair the window frame I cut some strip wood to size and ran one of Artesania's shapers over it,
This is the size of the pieces I needed,
The port side piece glued in place, i used the Cockpit canopy glue, worked out great no smudging,
and this is the starboard side after the repaired plank and window frame have been repaired and re varnished, next up will be the chain wales, they are supposed to sit above the lower carvings where that very thin bead is running along the top of the carvings, hopefully i will be able to cut back the beading in the area where the chain wales will sit, I never had the actual draughts when I attached the the long strip of carving, and with this model I may have to do what Maarten did and attach them under the carving strip, I know Rick milled out his carving strip and attached them over the carvings, but according to the draughts they sit above the carvings, but i suppose that is another option, also the chain wales supplied are too thick and they have to be thinned down and also tapered out to the edges,
thank you for visiting,
best regards John,
best regards John,
linings were too big so I wanted to check them out, this is the lining boards sitting over the kit plan, it looks ok to me,
