I principle a very good idea to get a curved beam, but also I have to agree with @jimmystratosI found an easier way to bend beams and not hammering a bunch of tacks into the bench. This way, you have more control of the bending and where it bends. I don't know why I did not think of this before.
That method is fine for an even curve, but a tightening curve would need more support point, hence lots of tacks.
Count the beams of a ship along appr. 2/3 of the ship length with similar curve! Easily you get 20 to 30 beamsYou would need a lot of identical beams to be worth making such a fancy jig Uwe!
Uwe,I principle a very good idea to get a curved beam, but also I have to agree with @jimmystratos
The best in my opinion is really to cut out the curved beam...... or I used also in the past this method, but off course more work
For each beam you need a sandwhich of three strips (lower part in photo) - on the upper part is the final result
put white glue between the strips
and put this sandwich between such a jig
Due to the glue the "beams" are keeping the curve very well ......
Depending of the curve which is necessary - bending will get much easier if the planks are soakedUwe,
Are the pieces “soaked” or is the moisture in the white glue enough to help with the “bending/curve” process to hold the shape?
Jan
This is the same method I use to make shields for medieval reenactment. You make a shield press with curved male and female forms and clamps to hold the assembly together. A thin shield made of slats glued together at right angles is historically correct.I principle a very good idea to get a curved beam, but also I have to agree with @jimmystratos
Fulcrum placement is essential for producing the amount of curvature in the right areas along the of the part. Since a solid piece of wood is composed of harder and softer volumes within it, and grain direction produces variations in its bending characteristic, some parts of the wood may hold a curve better than others. You make have to change the support points and bend a piece a second time to get the desired shape.I found an easier way to bend beams and not hammering a bunch of tacks into the bench. This way, you have more control of the bending and where it bends. I don't know why I did not think of this before.
