What are your thoughts on Homemade wood filler, wood glue + sawdust. Your favorite recipe?
You can buy black wood glueI have been using white wood glue and black graphite from a pencil, mixed into a paste for filling dark timber like ebony and African blackwood with great results.
I have on many occasions used the wood dust of boxwood and white glue for filling boxwood, but I reckon a pine coloured timber filler is less obvious.
www.antons.com.au
...it goes grey, when it dries, thought.
Moxis, epoxy I know. What are microballs?
Thank you Moxis. Would it also be possible to add sawdust to match the color of the wood?Hello StuG, microballs are microscopic glass particles, almost like dust. You can mix them with epoxy and get filler which you can compare with fibreglass. One of the benefits of this stuff is that you can control the consistency of the stuff from almost "water" (very little microballs) to thick stuff (lot of microballs). Very often I make a youghurt-like filler paste of it, which when curing is smoothing by itself or filling small grooves very easily. And after curing it is soft like wood so when you sand it, it will sand easily like wood around it and not like many 2 component "plastic padding" products which are hard as a stone.
By the way StuG, does your nickname mean Sturmgeschutz, which was a German assault gun during the second world war? A few years ago I made a model of this tank in scale 1/6.
TO SEA BURD, IS THE PAST WAX BY MIN-WAX IS THAT WHAT YOU ARE TALKING ABOUT, IN ALL THE METHODS ABOVE, HOW DO THE PRODUCTS REACT TO A TUNG OIL FINISH. GOD BLESS STAY SAFE Don
Sorry. Not sure how to answer that. Once the repair is made, sanded and allowed to dry the type of finish should not matter. If done properly the “wound” in the wood will never be seen or noticed. The finish applied over it simply seals it.WHAT ABOUT IF YOU USE OIL AS A FINISH, MINE STEAKED SO BAD JUST UGHLY SPOILED A NICE MODEL. GOD BLESS STAY SAFE Don
Hello Don, not all wood fillers are stainable (can adapt stain), also, fillers cannot accept oils. The nature of oils is to penetrate the wood. Putty or filler are polymers, they will not allow penetrating, This is why I think you have spots (where oil cannot penetrate).WHAT ABOUT IF YOU USE OIL AS A FINISH, MINE STEAKED SO BAD JUST UGHLY SPOILED A NICE MODEL. GOD BLESS STAY SAFE Don
