We are all keeping tuned ...![]()
Lovely work, Daniel. How did you make that half-round moulding?
Thanks so much! So it's Artesania Latina's micro shapers.Gennaro and Heinrich.... here we go. Remember i am not an expert at all so I did what it came to my head, with what I had in materials and tools.
Molding :
Glued a copy of the plan drawings. For this first intent I used my Wen scroll saw with a 28 TPI Plain blade.
If you zoom the first picture you will see that the cut has a LOT of defects. It was difficult for me to follow the drawing of the plan. I told this to a friend and the answer was... wrong blade. Use SPIRAL blades that you can cut on any direction without rotating the wood.
Then I used 41 TPI spiral blades
I draw the shape using the failed first attempt. And with the spiral blade I got what you can see at the right (after a little sanding too).
Then I applied my imagination. That is fine because this isn't the Statenjacht Utrecht.
I did the upper bean from a 1.5 x 5 mm pear wood plank. Glued it to the top and shaped with the dremel.
For the columns on the side I used the 2.5 x5 mm pear wood planks that came with the kit.
I cut it to 3 mm using my Micro Mark circular saw
The plier is to keep the wood in place for the picture. But I used it to push the wood and keep my fingers far away.
The I shaped the columns to a half moon using this tool from AL
Then I used a 2x2 mm white wood strip left over from other kits. And shaped in this way.
And glued over another 1.5x5 mm pear wood plank.
The door us just a rectangle of 1.6 mm thick Mahogany and the full frame was 1.6 mm Maple
Plus a few small square woods cut to size and rounded for the internal door frame.
That was all....
Cheers
Daniel
Looking really good! Were deck clamps included in the kit? Thanks.Deck beans assembling.... not glued as I need to do the interior. Each bean needs to be adjusted to make them fit.
Cheers
Daniel
WOW, Dan! You made huge progress. By looking at your images, the assembly goes well. Is the engineering kit design make it easy or a combination of both your skills and kit design? That cabin carving looks amazing, almost hard to believe it is a CNC.![]()
