Royal Caroline 1:50 YuanQing/ZHL [COMPLETED BUILD]
Hello friends. This will be my second build. My first project was the Black Pearl Golden Edition. For those who may want to visit my previous build, here is the link:
I learned a lot from my initial foray into wood modeling. I was very happy with my experience with the ZHL kit, so I chose to buy my 2nd model again from Max at ZHL.
As I was looking at various models, I was tempted to shoot for the moon and dive into one of the more advanced kits like the Royal Caroline 1:30 by ZHL, the San Felipe or the Le Soleil Royale. But, recognizing my limitations, I decided to be patient and hone my skills a bit longer and take on something that I thought I can handle.
So, finally I chose the Royal Caroline scale 1:50 made by YuanQing and sold by ZHL. Not to be confused for the exquisite Royal Caroline 1:30 scale which is bigger and has a lot more bells and whistles. I will have to defer building the RC 1:30 for a later time once I get more proficient.
As I did for my Black Pearl, which I gave to my son as a legacy gift, this next ship will be for my daughter. Hopefully, many many years from now, when I am gone, they will look at these ships and fondly remember me.
I will not show the contents of the kit in this thread because I already did a box opening thread earlier. If you wish to see what's in the box, I invite you to check out my thread at this link:
I hope you enjoy reading my thread and thanks to all our friends in this forum for their support and encouragement.
Reggie
I couldn't wait to dive right into it. After taking a quick inventory of the parts, I noticed that some pieces have just a small sticker to identify their part number. As a safety precaution, I took pictures of the different pieces and penciled in the part number in case the sticker falls off.
After I read through the assembly instructions, I cut the specific pieces I need using my Xacto knives.
By the way, I built this simple desk clamp from scrap pieces of wood to hold the keel in place while I worked on it.
Just a minor note, the laser cutting on some of the pieces didn't cut all the way through. Not a big deal, but I must've expected better especially after my great experience with the Black Pearl.
Before gluing anything, I thought it was important to dry fit the bulkheads to the keel. One nice feature of this ship is the lower deck piece which sits on the bulkheads and the deck has notches that fit into the bulkheads. This serves to make sure the bulkheads lay straight and in alignment.
To ensure that the bulkheads remain aligned when I glue them, I drew vertical pencil marks. I also drew horizontal lines on the bulkhead and the keel as a marker to make sure the bulkheads are inserted all the way through.
There is a piece on the bow which I am not sure if I should cut it or not. Decided to leave it alone for now. My guess is, it's probably intended to protect the bow from breaking while working on it.
On the stern, there are 4 pieces (part no. 14) which look like they require some slight trimming. There is another piece that is supposed to slide right into the notch, but it appears the notch needs to be about 2mm deeper so the other piece is flush against them.
Cool Reggie. I will be watching.
Moving on to assembling the bulkheads and decks.
After dry fitting the pieces to the keel, and making the appropriate markings, I am now ready to glue the bulkheads. I am using Elmers wood glue(brown). But first, I cleaned off the char on the pieces, or at least some of the char.
I then glued the bulkheads, at the same time dryfitting the lower deck and upper deck pieces to ensure proper alignment of the bulkheads. Also double checked against the pencil lines that I previously marked.
Without waiting for the bulkhead glue to dry, I immediately glued on the lower deck piece to ensure perfect alignment. This really worked like a charm. Nice fit for the pieces without need to stress any part. Kudos to the manufacturer.
Next I glued on the transom piece at the stern. Big mistake, as I will explain later on.
After the glue dried completely, I glued on the crossbars(Part 2b to 6b) that sit on top of bulkhead 2 to 6. These will support the main deck and gives the deck a slight bend towards the side, purportedly for drainage.
The main instructions did not show where part 1b is supposed to go, but it logically glues against the side of part 1 to provide support for the deck.
Likewise, part 7b is glued to side of bulkhead 7 (y). Also, at this time, I glued the lower deck for the aft quarters (x).
I was ready to glue the main deck, but paused because I thought I would first drill some preparatory holes on the lower deck, in case I decide later on to put LED lights. The kit does not provide for lighting, but I thought it might be kinda cool to have them.
The main deck is glued on top and is clamped on the side to follow the curved supports.
Remember earlier on I mentioned that I made a mistake on the transom piece? When I tried to dry fit the deck piece on the aft bulkheads, I realized the notches on the deck do not line up with the bulkheads. This is because the transom piece is angled so that the top of the bulkhead post is farther toward the back.
There is no "give" or flex because the next bulkhead post prevents me from stretching the piece.
The only way that I can think of is to unglue the transom, insert the deck notch to the bulkhead and slide it down a few cm where it sits slightly forward ... only then can I mount the transom.
Apologies if the above sounds confusing. By the way, I also took the opportunity to drill preparatory holes on the transom, in case I decide to put lights on the lanterns.
Next, I glued the top crossbars for bulkhead 6, 7 and 8. I then started planking the walls and the floor for the quarters. I used the precut 80mm teak strips provided in the kit.
So far, I am very pleased with this kit. It has been a straightforward build. The pieces generally fit very well. I especially like the lower deck piece that ensures that the bulkheads are square and aligned properly.
Until next time. Thanks for dropping by.
WOW Reggie! That is GOOD progress! :) The rear transom that was glued too early was luckily a happy fix. I really like the deck planking and the wood finish on the walls so far. I think once you have installed the LEDs, you will have great ambience inside these cabins!
Thank you @Heinrich .... although this RC model doesn't have the beautiful cabin furnishings that its more exquisite cousin has, perhaps lights will give it just enough ambience to add to its appeal. Appreciate the support. Keep safe always.
Nice methodical approach. We are all allowed an "oops" now and then, happily it was a relatively easy fix.
Thanks @DonRobinson ... mistakes are nothing more than opportunities to learn. This episode just reminded me to always look always ahead to future steps of the build. The beauty of working with me wood is that most of the time, mistakes can be rectified. Stay safe.
Reggie you are coming along nicely. Your problem with the transom is precisely why I waited on attaching mine on the Soleil Royal. I am enjoying your build.
@Jay ... you and I must be living in parallel universes... we share so many experiences and lessons in our builds. Thanks for stopping by and keep safe always.
I finished planking the deck and the walls of the aft galleries using the teak strips provided. I was still undecided whether to use tung oil or poly for the teak deck, so I ran a test to compare. The bare teak strips have a yellowish brown tint. The tung oil darkened them quite a bit and left them a bit walnut/chocolate brown. The poly darkened them a bit also, but not as much, and retained some of the natural yellowish tint of the teak.
I think I will go with the poly.
I then started planking the main deck area. The kit came with pre-cut 80mm teak strips, with consistent thickness and width. In my previous build, I used black acrilyc on the edge of the strips to simulate the caulking. This time, I thought I'd try the easy method and ...I am a bit embarrassed to say....used a Sharpie.
To simulate the treenails, I drilled two small holes and dabbed a black pencil into them.
I used the four-butt method of planking. I left out the sides for now and will finish the planking at a later time once I cut off the bulwarks.
At this time, I was supposed to glue down the upper deck pieces of the aft quarters. But I held off, because I decided that I will put in some LED lights (even though the kit does not provide for them). I just thought that, with all the beautiful windows in the ship, it would be a shame if I left them dark.
I decided to put LEDs in all the galleries, the lanterns, the stern windows, the space under the fore deck, and underneath the gratings.
I opened up the transom and marked where the windows of the resin piece will go, drilled and filed the openings. Tried it out for size. I thought it looked kinda neat.
I also pre-mounted three LEDs for the lanterns for later. Otherwise, it will be hard to do the lights once the decks are glued on.
Now that I have the lights pre-wired, I can close up the upper deck on the aft gallery.
Next, I worked a little bit on the bow section, in preparation for planking. I installed piece no. 57 on the bow.
At this time, I wish to mention that the kit comes with 2 sets of instructions... the first set is on the CD and is comprised of color photos and English instructions. But this is incomplete and you have to sometimes refer to a second set of instructions on the large printed paper which have very detailed drawings but are in Italian.
I say this because I had two pieces, part no. 15 and 16, which were not mentioned in the English CD instructions, but I found on the Italian set.
Now, as far as Part no. 16, it's supposed to go behind bulkhead no. 1, but it doesn't fit because the lower deck piece is on its way. So I had to cut part no.16 as shown.
Finally, following the example of some of our friends here, I added a bow filler to help with planking on the bow. This was a DIY piece made from scrap balsa wood in my stash.
That's it for now. Thanks for visiting. Keep safe everyone.
Reggie, you have been a busy dude. I also chose to do my planking with clear poly. Planking sure takes a lot of time to do doesn’t it? Love watching your progress.
A very busy man indeed! I am sure that the LEDs will add a lot to the final product, so you are right - it is best to do that now.
Hi @Jay... yes planking is time consuming, but in some ways I enjoy doing it for it can be almost meditative. It also helped that the kit came with pre-cut deck planking strips which ensures uniformity. Thanks Jay. Am following your excellent build also.
Ha ha ha...look who's talking @Heinrich ...if I am not mistaken, you are juggling 3 or 4 builds concurrently plus all the coordination work on the Bluenose. Hats off to you my friend. I only wish I had the energy that you have. Keep safe always.
