Thanks. I do have the plans. My problem is that some of the lines and the ones from the yards come down the mast to what appears to be a set of blocks at base of mast which I can do. However, the line running in the blocks comes out but the plan does not show where it ties off and there are no belay pins around the mast. mine is an old Constructo.Hi Fritz. I’m rigging a MGS Prince de Neufchâtel. Here are pics of the rigging plans.
My MGS kit came with 2 halves of white metal belay pin racks around each mast. 6 pins per rack. There are 4 eyes on the deck in a square pattern behind each mast for Burton Pendants to be tied to the mast racks. Hope this helps.Thanks. I do have the plans. My problem is that some of the lines and the ones from the yards come down the mast to what appears to be a set of blocks at base of mast which I can do. However, the line running in the blocks comes out but the plan does not show where it ties off and there are no belay pins around the mast. mine is an old Constructo.
Thanks. Nice work and appreciate the ideas. I may try to design a belay pin rack around the base of the mast. My other idea was to tie it off on the higher of the 2 blocks in the diagram.My MGS kit came with 2 halves of white metal belay pin racks around each mast. 6 pins per rack. There are 4 eyes on the deck in a square pattern behind each mast for Burton Pendants to be tied to the mast racks. Hope this helps.
Jaybird,Hi Fritz. I’m rigging a MGS Prince de Neufchâtel. Here are pics of the rigging plans.
Your finished product looks really fine. and thanks for sharing your technique and experience!People will see the riveting work even at a distance. The wheel with the small points give a pretty close scale and I find it better and cheaper then the individual copper plates.
Hallo @FritzNeed help with older constructo model prince de Neufchâtel. Plans numbering system seems to have errors and numbered line not going to any specific location and not to belay pins.
